Changes between Version 4 and Version 5 of InterWiki
May 8, 2022, 3:12:10 PM (2 years ago)
  • InterWiki
    v4 v5
    11= Support for InterWiki links
     2[[PageOutline(2-5,Contents,pullout)]]
    23
    34== Definition
    56An InterWiki link can be used for referring to a Wiki page located in another Wiki system, and by extension, to any object located in any other Web application, provided a simple URL mapping can be done.
    67
    7 InterWiki prefixes can even be used to simply introduce links to new protocols, such as `tsvn:` used by [trac:TortoiseSvn TortoiseSvn].
     8InterWiki prefixes can even be used to introduce links to new protocols, such as `tsvn:` used by [trac:TortoiseSvn TortoiseSvn].
    89
    910== Link Syntax
    1617Note that, as for InterTrac prefixes, '''InterWiki prefixes are case insensitive'''.
    1718
    18 The target Wiki URL is looked up in the `[interwiki]` section of TracIni or in the InterMapTxt wiki page, modeled after MeatBall:InterMapTxt. If a prefix is defined in both the `[interwiki]` section and InterMapTxt, the `[interwiki]` section takes precedence.
     19The target Wiki URL is looked up in the [TracIni#interwiki-section "[interwiki]"] section of TracIni and in the InterMapTxt wiki page, modeled after MeatBall:InterMapTxt. If a prefix is defined in both the `[interwiki]` section and InterMapTxt, the `[interwiki]` section takes precedence.
    1920
    20 In addition to traditional InterWiki links, where the target is simply ''appended'' to the URL, Trac supports parametric InterWiki URLs:
     21In addition to traditional !InterWiki links, where the target is simply ''appended'' to the URL, Trac supports parametric !InterWiki URLs:
    2122identifiers `$1`, `$2`, ... in the URL will be replaced by corresponding arguments.
    2223The argument list is formed by splitting the page identifier using the ":" separator.
    2324
    24 === [interwiki]
     25== [TracIni#interwiki-section "[interwiki]"]
    2526
    2627Every option in the `[interwiki]` section in TracIni defines one InterWiki prefix. The option name defines the prefix. The option value defines the URL, optionally followed by a description separated from the URL by whitespace. Parametric URLs are supported as well.
    3637== Examples
    3738
    38 If the following is an excerpt of the InterMapTxt page:
     39For the following excerpt of the InterMapTxt page:
    3940
    4041{{{
    4849----
    4950{{{
    50 PEP      http://www.python.org/peps/pep-$1.html           # Python Enhancement Proposal $1
     51PEP      http://www.python.org/peps/pep-$1.html           # Python Enhancement Proposal $1
    5152Trac-ML  http://thread.gmane.org/gmane.comp.version-control.subversion.trac.general/$1  # Message $1 in Trac Mailing List
    5253
    6162}}}
    6263
    63 Then,
    64  * `MoinMoin:InterWikiMap` should be rendered as MoinMoin:InterWikiMap and the ''title'' for that link would be "!InterWikiMap in !MoinMoin".
    65  * `Trac-ML:4346` should be rendered as Trac-ML:4346 and the ''title'' for that link would be "Message 4346 in Trac Mailing List".
     64Then,
     65 * `MoinMoin:InterWikiMap` will be rendered as MoinMoin:InterWikiMap and the ''title'' for that link will be "!InterWikiMap in !MoinMoin".
     66 * `Trac-ML:4346` will be rendered as Trac-ML:4346 and the ''title'' for that link will be "Message 4346 in Trac Mailing List".
     67
     68== List of Active Prefixes
     69
     70[[InterWiki]]
    6671
    6772----
