Changes between Version 1 and Version 2 of InterTrac
- Jun 10, 2010, 1:36:27 PM (14 years ago)
InterTrac
v1 v2 30 30 The prefix is case insensitive. 31 31 32 When a TracLink is enclosed in brackets, the alias is expanded. That is, `[th:ticket:1]` is displayed as `trachacks:ticket:1`, since `th` is an alias for `trachacks`. If the TracLink is not enclosed in brackets, then the alias is displayed as it is typed. 33 32 34 For convenience, there's also some alternative short-hand form, 33 35 where one can use an alias as an immediate prefix … … 36 38 37 39 == Examples == 38 39 {{{40 #!comment41 Besides the other environments run by the same server process42 (called ''sibling'' environments), which are automatically detected,43 Support for sibling environments has been disabled.44 See http://thread.gmane.org/gmane.comp.version-control.subversion.trac.devel/15745 }}}46 40 47 41 It is necessary to setup a configuration for the InterTrac facility. … … 57 51 # -- Link to an external Trac: 58 52 trac.title = Edgewall's Trac for Trac 59 trac.url = http://projects.edgewall.com/trac 60 trac.compat = false 53 trac.url = http://trac.edgewall.org 61 54 }}} 62 55 … … 69 62 70 63 Finally, the `.compat` option can be used to activate or disable 71 a ''compat bility'' mode:72 * If the targeted Trac is running a version below milestone:0.1073 ( r3526to be precise), then it doesn't know how to dispatch an InterTrac64 a ''compatibility'' mode: 65 * If the targeted Trac is running a version below [trac:milestone:0.10 0.10] 66 ([trac:r3526 r3526] to be precise), then it doesn't know how to dispatch an InterTrac 74 67 link, and it's up to the local Trac to prepare the correct link. 75 68 Not all links will work that way, but the most common do. 76 69 This is called the compatibility mode, and is `true` by default. 77 70 * If you know that the remote Trac knows how to dispatch InterTrac links, 78 you can explicit ely disable this compatibility mode and then ''any''71 you can explicitly disable this compatibility mode and then ''any'' 79 72 TracLinks can become an InterTrac link. 80 73 … … 94 87 * `trac:log:@3300:3330` trac:log:@3300:3330 95 88 * `[trac 3300:3330]` [trac 3300:3330] 89 * finally, to link to the start page of a remote trac, simply use its prefix followed by ':', inside an explicit link. Example: `[th: Trac Hacks]` (''since 0.11; note that the ''remote'' Trac has to run 0.11 for this to work'') 96 90 97 91 The generic form `intertrac_prefix:module:id` is translated … … 102 96 103 97 ---- 104 === Discussion ===105 106 I think that the `trac` prefix could even be set as a default in the `[intertrac]` TracIni section. --CB107 108 ----109 98 See also: TracLinks, InterWiki
