Changes between Version 14 and Version 15 of gsoc2011
May 26, 2011, 9:40:23 PM (13 years ago)
stefanl
  • gsoc2011
    v14 v15
    1111||'''1[[br]]key extension'''||"wms_title_eng" "my title" [[br]] "wms_title_ger" "mein titel"||---|| main question: should resolution happen at [[br]] i) write time, i.e. only wms_title goes into mapobject [[br]]  or [[br]] ii) read time, i.e. everything goes into mapobject, [[br]] corresponding key e.g. wms_title_ger is used for reading [[br]] [[br]] mapfile maintainable? validation? ||
    1212||'''2[[br]] runtime substitution''' ||---||DATA "shapes/rivers_%language%.shp" [[br]] [[br]] with ''language'' being a request parameter or global setting || already [http://mapserver.org/cgi/runsub.html implemented] in mapserver for certain parameters [[br]] [[br]] all required substitution scenarios (parameters) covered?  ||
    13 ||'''3[[br]] externalization''' [[br]] [[br]] using external files [[br]] ''lang.eng''  [[br]] ''lang.ger'' || "wms_title" "IDC_TITLE" [[br]] [[br]] IDC_TITLE=my title [[br]] IDC_TITLE=mein titel || DATA "IDC_SHAPES_RIVERS" [[br]] [[br]] IDC_SHAPES_RIVERS=shapes/rivers_eng.shp [[br]]  IDC_SHAPES_RIVERS=shapes/rivers_ger.shp [[br]] or [[br]] IDC_SHAPES_RIVERS=shapes/eng/rivers.shp [[br]] IDC_SHAPES_RIVERS=shapes/ger/rivers.shp|| common way of internationalization,  [[br]] many tools available to externalize strings [[br]] [[br]] at which time the externalized [[br]] value should be resolved (while parsing mapfile,  [[br]] during msApplySubstitutions, ...)?||
     13||'''3[[br]] externalization''' [[br]] [[br]] using external files [[br]] ''lang.eng''  [[br]] ''lang.ger'' || "wms_title" "IDC_TITLE" [[br]] [[br]] IDC_TITLE=my title [[br]] IDC_TITLE=mein titel || DATA "IDC_SHAPES_RIVERS" [[br]] [[br]] IDC_SHAPES_RIVERS=shapes/rivers_eng.shp [[br]]  IDC_SHAPES_RIVERS=shapes/rivers_ger.shp [[br]] or [[br]] IDC_SHAPES_RIVERS=shapes/eng/rivers.shp [[br]] IDC_SHAPES_RIVERS=shapes/ger/rivers.shp|| common way of internationalization,  [[br]] many tools available to externalize strings [[br]] [[br]] at which time the externalized value should be resolved [[br]] (while parsing mapfile,  [[br]] during msApplySubstitutions, ...)?||
    1414||'''4[[br]] merge''' [[br]] [[br]] using INCLUDE ||---|| ''standard.map'' [[br]] LAYER [[br]]... [[br]] NAME "rivers" [[br]] INCLUDE "rivers.map" [[br]] ... [[br]] [[br]] ''eng/rivers.map'' [[br]] DATA "shapes/rivers_eng.shp" [[br]] [[br]] ''ger/rivers.map'' [[br]] DATA "shapes/rivers_ger.shp" || mostly [http://mapserver.org/mapfile/Include.html implemented] in mapserver [[br]] [[br]] based on languange the corresponding map file is included||
    15 ||'''5[[br]] override''' [[br]] [[br]] override certain values [[br]] of the original mapfile [[br]] e.g. with ''override.ger''|| "wms_title" "my title" !#1 [[br]] [[br]] 1="mein titel" ||LAYER [[br]]... [[br]] NAME "rivers" [[br]]  DATA "shapes/rivers_eng.shp" !#2 [[br]] ... [[br]] [[br]] 2="shapes/rivers_ger.shp"|| identification of "key" e.g. by comment like !#1 and !#2[[br]] [[br]] other option could use XPath-like syntax [[br]] e.g. [[br]] WEB/METADATA/wms_title="mein titel" [[br]] LAYER[river]/DATA=""shapes/rivers_ger.shp"||
     15||'''5[[br]] override''' [[br]] [[br]] override certain values [[br]] of the original mapfile [[br]] e.g. with ''override.ger''|| "wms_title" "my title" !#1 [[br]] [[br]] 1="mein titel" ||LAYER [[br]]... [[br]] NAME "rivers" [[br]]  DATA "shapes/rivers_eng.shp" !#2 [[br]] ... [[br]] [[br]] 2="shapes/rivers_ger.shp"|| identification of "key" e.g. by comment like !#1 and !#2[[br]] [[br]] other option could use XPath-like syntax [[br]] e.g. [[br]] WEB/METADATA/wms_title="mein titel" [[br]] LAYER[rivers]/DATA="shapes/rivers_ger.shp"||
    1616
    1717=== status reports ===
