Changes between Version 7 and Version 8 of VirtualSpatialData
- Jan 27, 2009, 4:08:22 PM (15 years ago)
VirtualSpatialData
v7 v8 108 108 The virtual file can be called anything you want and be placed anywhere. I'll assume its called virtual.ovf (OGR Virtual File = .ovf). 109 109 110 The !<SrcLayer> parameter is a table name. If you wish to join tables or select only certain columns, you can use an SQL statement by omitting !<SrcLayer> and including !<SrcSQL>select table.name, table.x, table.y from table!</SrcSQL> in its place. Note that in the !GeometryField, you may need to refer to the attributes x and y as table.x and table.y in this case.110 The <!SrcLayer> parameter is a table name. If you wish to join tables or select only certain columns, you can use an SQL statement by omitting <!SrcLayer> and including <!SrcSQL>select table.name, table.x, table.y from table</!SrcSQL> in its place. Note that in the !GeometryField, you may need to refer to the attributes x and y as table.x and table.y in this case. 111 111 112 112 === Testing using ogrinfo ===
