Changes between Version 10 and Version 11 of UsingMapOWSCommon
- Jun 20, 2007, 4:42:24 AM (17 years ago)
UsingMapOWSCommon
v10 v11 16 16 With the exception of msOWSCommonExceptionReport, ALL functions return an XML chunk. It is the responsibility of the calling code to setup the root element with correct namespace decls and schema pointers 17 17 18 msOWSCommonExceptionReport returns an entire, complete and valid XML document, as it is the only XML in OWS Common which is designed to be implemented standalone. In this case, the calling code must instantiate an [http://www.xmlsoft.org/html/libxml-tree.html#xmlN odePtrxmlNewDoc] object.18 msOWSCommonExceptionReport returns an entire, complete and valid XML document, as it is the only XML in OWS Common which is designed to be implemented standalone. In this case, the calling code must instantiate an [http://www.xmlsoft.org/html/libxml-tree.html#xmlNewDoc xmlNewDoc] object. 19 19 20 20 EXAMPLE 1: create a service Exception
