| 1 | |
| 2 | Using mapowscommon.c |
| 3 | |
| 4 | mapowscommon implements the OGC OWS Common Specification |
| 5 | |
| 6 | - version 1.0.0 |
| 7 | - OGC document: OGC 05-008 |
| 8 | |
| 9 | The library uses libxml2 (http://www.xmlsoft.org/) to create |
| 10 | XML objects. |
| 11 | |
| 12 | The library uses the tree and parser modules of libxml2. |
| 13 | |
| 14 | The library returns xmlNodePtr objects to the calling code. |
| 15 | |
| 16 | To implement, the calling code must instantiate an xmlNewDoc |
| 17 | object: |
| 18 | |
| 19 | {{{ |
| 20 | /* use libxml2: */ |
| 21 | |
| 22 | #include "libxml/parser.h" |
| 23 | #include "libxml/tree.h" |
| 24 | |
| 25 | #include "mapowscommon.h" |
| 26 | |
| 27 | static int msSOSException(mapObj *map, char *locator, char *exceptionCode) |
| 28 | xmlDocPtr psDoc = NULL; |
| 29 | xmlNodePtr psRootNode = NULL; |
| 30 | xmlChar *buffer = NULL; |
| 31 | int size = 0; |
| 32 | |
| 33 | /* create XML document object */ |
| 34 | psDoc = xmlNewDoc(BAD_CAST "1.0"); |
| 35 | |
| 36 | /* generate a service exception object */ |
| 37 | psRootNode = msOWSCommonExceptionReport(msEncodeHTMLEntities(msOWSGetSchemasLocation(map)), pszSOSVersion, msOWSGetLanguage(map, "exception"), exceptionCode, locator, msEncodeHTMLEntities(msGetErrorString("\n"))); |
| 38 | |
| 39 | /* set the root element of the document */ |
| 40 | xmlDocSetRootElement(psDoc, psRootNode); |
| 41 | |
| 42 | /* set the namespace of the document */ |
| 43 | xmlSetNs(psRootNode, xmlNewNs(psRootNode, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_URI, BAD_CAST MS_OWSCOMMON_OWS_NAMESPACE_PREFIX)); |
| 44 | msIO_printf("Content-type: text/xml%c%c",10,10); |
| 45 | |
| 46 | /* dump the libxml2 object to a string for output */ |
| 47 | xmlDocDumpFormatMemoryEnc(psDoc, &buffer, &size, "ISO-8859-1", 1); |
| 48 | |
| 49 | msIO_printf("%s", buffer); |
| 50 | |
| 51 | /*free buffer and the document */ |
| 52 | xmlFree(buffer); |
| 53 | xmlFreeDoc(psDoc); |
| 54 | |
| 55 | /* clear error since we have already reported it */ |
| 56 | msResetErrorList(); |
| 57 | |
| 58 | return MS_FAILURE; |
| 59 | } |
| 60 | |
| 61 | |
| 62 | }}} |
| 63 | |
| 64 | NOTES: |
| 65 | |
| 66 | - with the exception of msOWSCommonExceptionReport, ALL functions return |
| 67 | an XML chunk. It is the responsibility of the calling code to setup the |
| 68 | root element with correct namespace decls and schema pointers |
| 69 | |
| 70 | - msOWSCommonExceptionReport returns an entire, complete and valid XML |
| 71 | document, as it is the only XML in OWS Common which is designed to be |
| 72 | implemented standalone |
