Changes between Version 3 and Version 4 of TinyOWSModGeocacheIntegration
- Aug 5, 2011, 7:31:58 AM (13 years ago)
v3 v4 37 37 == Build system integration == 38 38 39 Single build system or multiple/separate ones? It seems that we need a mix of both... Daniel has some ideas 39 * Single build system or multiple/separate ones? It seems that we need a mix of both... 40 * Linux uses autoconf + Makefiles in all cases ... a merge, or at least some sharing is feasible 41 * What about Windows? 40 42 41 43 == Source and binary packaging == 44 45 * Individual packages as follows? 46 * mapserver-6.0.1.tar.gz 47 * tinyows-1.0.0.tar.gz 48 * mod-geocache-0.4.0.tar.gz 49 * What about the combined suite? Do we ever want to distribute it as a single source package or not? 50 * Any naming recommendations for binary packagers? 42 51 43 52 == Mailing lists == … … 87 96 88 97 == Tickets (Trac) == 98 99 * All projects to use the same http://trac.osgeo.org/mapserver/ 100 * RFC 70: TinyOWS use a Trac, but as only few tickets are still open, an efficient way is just to create them back in MapServer one. Should imply a new component in MapServer Trac, called: TinyOWS. 101 * RFC 71: There are currently no open bugs to transition to the MapServer trac. The open feature enhancements will be manually migrated to the MapServer trac instance. 102 103 == Wiki == 104 All projects to use http://trac.osgeo.org/mapserver/ ? 89 105 90 106 == Website and documentation == … … 93 109 * How do we deal with releases (and docs updates) that are not synchronized? 94 110 95 * RFC 70 says: tinyows.org domain could be redirected to the coming MapServer TinyOWS documentation pages. 111 * All projects to adopt the same Sphinx/RST tools as current MapServer docs 112 * RFC 70 says: Move TinyOWS trac Wiki documentation to RST syntax. [...] tinyows.org domain could be redirected to the coming MapServer TinyOWS documentation pages. 96 113 * RFC 71 says: The mod-geocache documentation is rather sparse, and consists essentially of a commented configuration file. There will have to be an effort to add documentation to the main mapserver doc site, and to migrate the few wiki pages from the google-code hosting.
