Changes between Version 1 and Version 2 of Solaris8Build
- Jan 26, 2009, 12:38:42 PM (15 years ago)
Solaris8Build
v1 v2 3 3 !MapServer v3.6.4 4 4 5 Libraries I installed to get this, PHP and MapLab?working:5 Libraries I installed to get this, PHP and !MapLab working: 6 6 7 7 * gcc (3.2) (Sun linker used) … … 26 26 For ./mapscript/php3/Makefile?.in add "LDFLAGS = @LDFLAGS@" after CFLAGS and then add "$(LDFLAGS)" right after "$(LD)" in the first two make directives. 27 27 28 Assuming you're using Apaceh, add to the httpd.conf file the directive (you can leave off the pgsql directory if you're not using PostgreSQL): SetEnv LD_LIBRARY_PATH /usr/local/lib:/usr/local/pgsql/lib28 Assuming you're using Apaceh, add to the httpd.conf file the directive (you can leave off the pgsql directory if you're not using PostgreSQL): !SetEnv LD_LIBRARY_PATH /usr/local/lib:/usr/local/pgsql/lib 29 29 30 NOTE: To avoid all the LD-related shenanigans above, I found that the "--enable-runpath" option might avoid having to do all that (and possibly the SetEnv addition to the Apache configuration). Using that option was not fully tested.30 NOTE: To avoid all the LD-related shenanigans above, I found that the "--enable-runpath" option might avoid having to do all that (and possibly the !SetEnv addition to the Apache configuration). Using that option was not fully tested. 31 31 32 32 Run configure with your options, these were mine (the "--enable-interal-ld-detect" is important on Solaris):
