Changes between Version 31 and Version 32 of RenderingOsmData
- Nov 18, 2011, 1:38:43 PM (12 years ago)
RenderingOsmData
v31 v32 16 16 == Importing !OpenStreetMap Data == 17 17 18 This howto will take australian data as an example. Note: if you already have imported OSM data, see the section named "Using an existing database" below.18 This howto will take australian data as an example. Note: if you already have imported OSM data, see the section "[#Usinganexistingdatabase Using an existing database]" below. 19 19 20 20 === Download === … … 183 183 == Using an existing database == 184 184 185 If you already have a postgis database with OSM data imported, all there is left to do (besides compiling mapserver with postgis support) is editing generate_style.py , around. line 72 change186 187 {{{ 188 'db_connection': '"host=localhost dbname=osm user=osm password=osm port=5432"'185 If you already have a postgis database with OSM data imported, all there is left to do (besides compiling mapserver with postgis support) is editing generate_style.py. at approx. line 72 change 186 187 {{{ 188 'db_connection': '"host=localhost dbname=osm user=osm password=osm port=5432"' 189 189 }}} 190 190
