Changes between Initial Version and Version 1 of PerlMapScriptExamples35ex4
Jan 29, 2009, 6:39:17 AM (15 years ago)
jmckenna
  • PerlMapScriptExamples35ex4
     1= find.pl =
     2The boundary.tar.gz is not available because I can't upload it. It is not required for the script to work, only to run the example. -sw http://www.highwayengineer.co.medina.oh.us/boundary.tar.gz
     4{{{
     5#!perl
     6#!/usr/bin/perl -w
     7#
     8# Copyright (C) 2002, Lowell Filak.
     9# You may distribute this file under the terms of the Artistic
     10# License.
     11#
     12# Given a shapefile name, item name, & item value this routine will dump out
     13#   the matching records.
     14#
     15# Required modules are mapscript (installed as part of make install),
     16#   Getopt (normally included with Perl), & XBase.
     17#   Please download boundary.tar.gz also, and:
     18#     tar -xf boundary.tar.gz --ungzip
     19#
     20# Suggested run line = ./find.pl -file=boundary -item=loc_name -value='Medina City'
     21use mapscript;
     22use Getopt::Long;
     23use XBase;
     24#
     25# Retrieve the input values.
     26GetOptions('file=s' => \$file, 'item=s' => \$item, 'value=s' => \$value);
     27#
     28# Check the input values.
     29if ( (!$file) || (!$item) || (!$value) ) {
     30  print "Syntax: find.pl -file=[filename] -item=[item_name] -value=[item_value]\n";
     31  exit 0;
     32}
     33#
     34# Open the existing shapefile.
     35$shapefile = new shapefileObj($file, -1) or die "Unable to open shapefile $file.";
     36#
     37# Print out the entered values.
     38print "Shapefile: $file\nItem Name: $item\nItem Value: $value\n\n";
     39#
     40# Open the db handle.
     41my $dbh = new XBase "$file" or die XBase->errstr;
     42#
     43# Grab and process the information.
     44my @row;
     45#
     46# Set the number of results to 0.
     47my $results = 0;
     48#
     49# Open a new shape object to hold the found shapes.
     50my $shape = new shapeObj(-1);
     51#
     52# Use xbase to query by attribute.
     53#
     54# Loop through each record (there are experimental modules for using indexes
     55#   available according to xbase man page).
     56for ($record=0; $record<$dbh->last_record; $record++){
     57  #
     58  # Grab the record.
     59  my @row = $dbh->get_record($record, "$item") or die $dbh->errstr;
     60  #
     61  # Is the record marked for deletion.
     62  my $deleted = $row[0];
     63  if ( $deleted == 1 ) {
     64    #
     65    # If so then skip it.
     66    next;
     67  }
     68   else {
     69    #
     70    # Fall through.
     71   }
     72  #
     73  # Set the value for the search field.
     74  my $fndvalue = $row[1];
     75  #
     76  # Does the value from the field match the query.
     77  if ( "$fndvalue" ne "$value" ) {
     78    #
     79    # If not skip it.
     80    next;
     81  }
     82   else {
     83    #
     84    # Fall through.
     85   }
     86  #
     87  # Print the found record information.
     88  print "The Row Found: $record\nThe Value Found: $fndvalue - go figure :-)\n";
     89  #
     90  # Increment the results counter.
     91  $results = $results + 1;
     92  #
     93  # Grab shape #$record and stick it into the shape holder.
     94  $shapefile->get($record, $shape);
     95  #
     96  # Get the bounds of the shape.
     97  my $minx = $shape->{bounds}->{minx};
     98  my $miny = $shape->{bounds}->{miny};
     99  my $maxx = $shape->{bounds}->{maxx};
     100  my $maxy = $shape->{bounds}->{maxy};
     101  #
     102  # Print the bounds of the shape.
     103  printf "bounds (%f,%f) (%f,%f)\n", $minx, $miny, $maxx, $maxy;
     104}
     105#
     106# Print the number of records found.
     107print "Number of Results: $results\n";
     108}}}
     109
     110----
     111[wiki:PerlMapScript back to PerlMapScript]
