Changes between Initial Version and Version 1 of PerlMapScriptExamples35ex1
Jan 28, 2009, 1:53:35 PM (15 years ago)
jmckenna
  • PerlMapScriptExamples35ex1
     1create_tileindex.pl
     3#!/usr/bin/perl
     4use strict;
     5#use warnings;
     7use XBase;
     8use Cwd;
     9use mapscript;
     10use Getopt::Long;
     11use Image::Size;
     12use File::Basename;
     13use File::Find;
     14use Pod::Usage;
     15
     16our $version = 0.91;
     17our $ms37above = 0;             # default mapserver version < 3.7
     18
     19BEGIN {
     20  my ($msmajor, $msminor) = ($mapscript::MS_VERSION =~ /^(\d+)\.(\d+)/o);
     21  if ($msmajor > 3 or ($msmajor == 3 and $msminor > 6)) {
     22    $ms37above = 1;
     23  }
     24}
     25
     26# variables for command line arguments
     27my $verbose   = 0;              # verbosity level
     28my $imagedir  = getcwd;         # image directory, default is current dir
     29my $shapename = 'tileindex';    # name of shapefile to be created
     30my $extension = 'tif';          # extension of image files
     31my $imgcatdrv = '';             # image catalog drive and path
     32my $imgcatsbd = '';             # image catalog share basepath
     33my $help      = '';             # you want help? you'll get it!
     34
     35GetOptions('verbose+'        => \$verbose,
     36           'imagedir:s'      => \$imagedir,
     37           'tileindexname:s' => \$shapename,
     38           'extension:s'     => \$extension,
     39           'drvimgcat:s'     => \$imgcatdrv,
     40           'sbdimgcat:s'     => \$imgcatsbd,
     41           'help'            => \$help);
     42
     43pod2usage( { -exitval => 1,
     44             -verbose => 3} ) if $help;
     45
     46pod2usage( { -exitval => 2,
     47             -verbose => 1,
     48             -output => \*STDERR} ) unless $imagedir and $shapename and $extensi
     49on;
     50
     51my $NL = "\n";
     52
     53# If tileindex shape exists, delete it!
     54for my $shpfile ("$shapename.shp", "$shapename.shx", "$shapename.dbf") {
     55  if (-e $shpfile) {
     56    print "deleting $shpfile\n" if $verbose > 1;
     57    unlink $shpfile
     58      or die "ERROR: Could not delete $shpfile: $!\n";
     59  }
     60}
     61
     62die "ERROR: Not a directory $imagedir: $!\n" unless -d $imagedir;
     63my @tfws;
     64find( \&push_tfws, $imagedir);
     65die "ERROR: No .tfw files in directory $imagedir\n" if $#tfws < 0;
     66
     67# create new shapefile
     68print "creating tileindex $shapename.shp\n\n" if $verbose > 1;
     69my $shapefile = $ms37above ? mapscript::shapefileObj->new("$shapename.shp",$mapscript::MS_SHAPEFILE_POLYGON) : shapefileObj->new("$shapename.shp",$mapscript::MS_SHAPEFILE_POLYGON);
     70my $basename = $shapename =~ /\.shp$/ ? basename($shapename,('.shp')) : $shapename;
     71# create dBASE-file for shapefile
     72unlink "$shapename.dbf";
     73my $table =  XBase->create("name"        => "$shapename.dbf",
     74                  "field_names"    => [ qw/ IMAGE XMIN YMIN XMAX YMAX LOCATION /
     75 ],
     76                  "field_types"    => [ qw/ C N N N N C/ ],
     77                  "field_lengths"  => [ qw/ 75 20 20 20 20 127/ ],
     78                  "field_decimals" => [ undef, 8, 8, 8, 8, undef ]);
     79
     80# create point object for usage in shapefile
     81my $point = $ms37above ? mapscript::pointObj->new() : pointObj->new() ;
     82
     83my $i = 0;                      # record counter
     84foreach my $tfwfile (@tfws) {   # step through all tfw-files
     85  my $image = imagename($tfwfile); # name of image file
     86  print "Image is $image...\n" if $verbose;
     87  next unless -r $image;        # skip if image does not exist
     88  print "Processing $tfwfile...\n" if $verbose;
     89  # calculate image coordinates
     90  my $tfw = read_tfw("$tfwfile", $image);
     91  # create new shape object which will contain the new polygon
     92  my $shp = $ms37above ? mapscript::shapeObj->new($mapscript::MS_POLYGON) : shapeObj->new($mapscript::MS_POLYGON);
     93  # create new line object which will receive the coordinates
     94  my $line = $ms37above  ? mapscript::lineObj->new() : lineObj->new();
     95  my ($minx, $miny, $maxx, $maxy) = ();
     96  foreach my $rk (@$tfw) {      # add all coordinates
     97    print $$rk[0], ',', $$rk[1], $NL if $verbose > 1;
     98    $point->{'x'} = $$rk[0];    # into point object
     99    $point->{'y'} = $$rk[1];
     100    $line->add($point);         # and point into line
     101    save_maxmin($rk, \$minx, \$miny, \$maxx, \$maxy);
     102  }
     103  # write record into dbase file
     104  (my $avimage = $image) =~ s!$imgcatsbd!$imgcatdrv!o;
     105  $avimage =~ s!/!\\!og;
     106  $table->set_record($i,$avimage,$minx,$miny,$maxx,$maxy,$image);
     107  $shp->add($line);             # add line to shape
     108  $shapefile->add($shp);        # add shape to shapefile
     109  $i++;                         # increase record counter
     110  print $NL if $verbose > 1;
     111}
     112
     113undef $shapefile;               # close shapefile
     114undef $table;                   # close dbase table
     115system('shptree', $shapename);
     116print "Done.\n" if $verbose;
     117exit 0;
     118
     119#---------------------------------------------------------------------
     120# function save_maxmin - save maximum/minimum coordinates
     121#
     122# description: compare current point koordinates with max/min x/y values
     123#              and set these new if appropriate
     124#
     125# parameters : $rk   - reference to coordinate list
     126#              $minx - reference to min x value
     127#              $miny - reference to min y value
     128#              $maxx - reference to max x value
     129#              $maxy - reference to max y value
     130#
     131# returns    : nothing
     132#
     133# MWS remarks:
     134#
     135#---------------------------------------------------------------------
     136sub save_maxmin {
     137  my ($rk, $minx, $miny, $maxx, $maxy) = @_;
     138  $$minx = $$minx ? $$rk[0] < $$minx ? $$rk[0] : $$minx : $$rk[0];
     139  $$maxx = $$maxx ? $$rk[0] > $$maxx ? $$rk[0] : $$maxx : $$rk[0];
     140  $$miny = $$miny ? $$rk[1] < $$miny ? $$rk[1] : $$miny : $$rk[1];
     141  $$maxy = $$maxy ? $$rk[1] > $$maxy ? $$rk[1] : $$maxy : $$rk[1];
     142  print STDERR "$$minx, $$miny, $$maxx, $$maxy\n" if $verbose > 1;
     143}
     144
     145
     146#---------------------------------------------------------------------
     147# function imagename - return name of image for given tfw file
     148#
     149# description: removes extension .tfw and adds known extension
     150#              from global variable $extension
     151#
     152# parameters : $img - name of tfw file
     153#
     154# returns    : string with image name
     155#---------------------------------------------------------------------
     156sub imagename{
     157  my $img = shift;
     158  $img =~ s/\.tfw$//o;
     159  return "$img.$extension";
     160}
     161
     162#---------------------------------------------------------------------
     163# function read_tfw - read tfwfile and image, return coordinates
     164#
     165# description: reads tfw file and retrieves image size, creates a list
     166#              of the corner coordinates
     167#              Uses Image::Size to get the size of the image
     168#
     169# parameters : $tfwfile - name of tfw file
     170#              $image   - name of image
     171#
     172# returns    : pointer to list of coordinates
     173#
     174#---------------------------------------------------------------------
     175sub read_tfw{
     176  my ($tfwfile, $image) = @_;
     177  my ($ix, $iy, $desc) = imgsize($image);
     178  die "$desc" unless $ix;
     179  open(I, "< $tfwfile") or die "Can't read $tfwfile: $!";
     180  my @lines = <I>;              # read file into array
     181  my ($dx) =  ($lines[0] =~ /(\S+)/)[0];
     182  my ($dy) =  ($lines[3] =~ /(\S+)/)[0];
     183  my ($ulx) = ($lines[4] =~ /(\S+)/)[0];
     184  my ($uly) = ($lines[5] =~ /(\S+)/)[0];
     185  close I;
     186  my $coords = [[$ulx,$uly],
     187                  [$ulx + $dx * $ix, $uly],
     188                  [$ulx + $dx * $ix, $uly + $dy * $iy],
     189                  [$ulx, $uly + $dy * $iy],
     190                  [$ulx,$uly]];
     191  return $coords;
     192}
     193
     194#---------------------------------------------------------------------
     195# function push_tfws - push all tfw-files on global stack @tfw
     196#
     197# description:
     198#
     199# parameters :
     200#
     201# returns    :
     202#
     203# MWS remarks:
     204#
     205#---------------------------------------------------------------------
     206sub push_tfws{
     207  push(@tfws, $File::Find::name) if /\.tfw$/;
     208}
     209
     2101;
     211
     212__END__
     213
     214=head1 NAME
     215
     216create_tileindex.pl - create tileindex for mapserver and image catalog for ArcView
     217
     218=head1 SYNOPSIS
     219
     220  create_tileindex.pl [--tileindexname hitif]                        [--extension tif]                              [--imagedir /tmp/hitif]                        [--drvimgcat y:\]                              [--sbdimgcat /data]                            [--verbose]                                    [--help]
     221
     222=head1 DESCRIPTION
     223
     224create_tileindex.pl creates a tileindex shapefile and dbase file for the usage of tiled georeferenced images in mapserver and ArcView (TM ESRI).
     225
     226The images can be stored in a subdirectory tree, as F<create_tileindex.pl> performs a file-find starting from the given imagedir.
     227
     228After creating the tileindex, a F<shptree> command is issued to speed up mapserver access to the tiles.
     229
     230=head1 EXAMPLE
     231
     232=head2 Simple usage
     233
     234Cd into base directory of the images, issue the F<create_tileindex.pl> command.
     235A tileindex named F<tileindex> will be created in the current directory.
     236This is sufficient for mapserver usage and ArcView usage with a F<drivemap.txt> file.
     237
     238=head2 Complex usage
     239
     240  create_tileindex.pl --tileindexname muctiles                        --extension tif                                 --imagedir /data/tifplan                        --sbdimgcat /data                               --drvimgcat "y:"
     241
     242Short notation:
     243
     244  create_tileindex.pl -t muctiles -i /data/tifplan -s /data -d "y:"
     245
     246This command creates the tileindex with the name F<muctiles> in the current directory.
     247
     248The extension of the searched image files is tif (this is the default value, so it could have been omitted).
     249
     250The starting directory of the search for image files is F</data/tifplan>.
     251
     252For the usage as an image catalog, the directory part of the image filenames is modified by
     253
     254=over 4
     255
     256=item
     257
     258replacing from the start the value of the --sbdimgcat value with the --drvimgcat value
     259
     260=item
     261
     262replacing all forward slashes / with backslashes
     263=back
     264
     265The modified filenames are placed in the item C<IMAGE>. It's length is 75 characters.
     266
     267(For ArcView experts: The same effect could be achieved by placing an appropriate F<DRIVEMAP.TXT> in the appropriate place.)
     268
     269=head1 COMMAND LINE ARGUMENTS
     270
     271Every argument name can be given in one-dash-one-letter notation or shortened ad libitum.
     272
     273=over 4
     274
     275=item --tileindexname (optional)
     276
     277Name (without extension!) of the tileindex to be created. If the tileindexname contains no directory part, the tileindex is created in the current directory.
     278If this argument is omitted, the name F<tileindex> is used.
     279
     280=item --extension (optional)
     281
     282Extension of the image files to be searched. Defaults to C<tif>.
     283
     284=item --imagedir (optional)
     285
     286Base directory where the image files are stored under. The search for the images starts here.
     287
     288=item drvimgcat (optional)
     289
     290Drive letter and eventually path (Windows notation) to be used when accessing the images from ArcView/Windows via the image catalog.
     291
     292=item sbdimgcat (optional)
     293
     294Windows share base directory of the image files (Unix notation). This directory will be replaced by the C<drvimgcat> value.
     295
     296=item verbose (optional)
     297
     298Toggles verbose output. One -v argument prints the names of the processed image files, two or more additionally print the corner coordinates of the images.
     299
     300=item help (optional)
     301
     302Print this documentation to stdout and exit.
     303
     304=back
     305
     306=head2 Tileindex in Mapserver
     307
     308F<create_tileindex.pl> places the names of the image file in the item C<LOCATION>, which is the default for mapserver. It's length is 127 characters.
     309To use the created tileindex in mapserver, add the following lines in your mapfile:
     310
     311  LAYER
     312    NAME bgl99
     313    TILEINDEX "/home/springm/perl/muctiles"
     314    TYPE raster
     315  END
     316
     317=head2 Image catalog in ArcView
     318
     319The created dbase file can be used as an image catalog in ArcView. To use this image catalog, perform the following steps (quoted from ArcView help):
     320
     321=over 4
     322
     323=item
     324
     325Click the Add Theme button.
     326
     327=item
     328
     329In the Data Source Types box, choose Image Data Source.
     330
     331=item
     332
     333Navigate to the directory that contains the image catalog you want to add.
     334Double-click on the directory name to list the image catalogs sources it contiains.
     335
     336=item
     337
     338Double-click the image catalog source you wish to add.
     339
     340=back
     341
     342=head1 LIMITATIONS
     343
     344F<create_tileindex.pl> does not yet work with geotifs a.k.a. tif files which include the reference information in their header.
     345
     346=head1 REQUIREMENTS
     347
     348F<create_tileindex.pl> uses perl 5.6.1 and is based on C<mapscript>, Version 3.6 or above.
     349
     350It further uses the Perl modules C<XBase>, C<Image::Size> and <Pod::Usage>. You can get them from L<CPAN|http://search.cpan.org>.
     351
     352=head1 AUTHOR
     353
     354Markus W. Spring <m.spring@gmx.de>
     355
     356=head1 COPYRIGHT AND DISCLAIMER
     357
     358    This program is Copyright 2002.2003 by Markus W. Spring. This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version.
     359
     360    This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
     361
     362    If you do not have a copy of the GNU General Public License write to the
     363    Free Software Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA.
     364
     365=cut
     366
     367# Local variables:
     368# compile-command: "perl create_tileindex.pl -t ihk_tk50 -i /data/ihk/tk50 -e tif -v -v"
     369# End:
