Changes between Version 18 and Version 19 of PerlMapScriptExamples35
- Jan 29, 2009, 7:07:10 AM (15 years ago)
v18 v19 47 47 Simple script to project a shapefile given 2 Proj.4 projection definition strings. 48 48 49 * [wiki:PerlMapScriptExamples35ex12 plsscalc.pl] submitted by Puneet Kishor <pkishor@geoanalytics.com> (Not really a MapScript example, but potentially useful for mapping apps)49 * [wiki:PerlMapScriptExamples35ex12 plsscalc.pl] submitted by Puneet Kishor <pkishor@geoanalytics.com> (Not really a !MapScript example, but potentially useful for mapping apps) 50 50 51 51 Given a township, range, section, quarter-section, and a search radius in miles, this script will spit out all the quarter-sections within the search radius of the origin. Assumes regular and continuous coverage of PLSS. … … 53 53 * [wiki:PerlMapScriptExamples35ex13 thin.pl] submitted by Stephen Lime <steve.lime@dnr.state.mn.us> 54 54 55 (thin.pl) is perl mapscript that does line thinning. It's a port of the ArcView?thinning script. A bit slow but seems to work fine.55 (thin.pl) is perl mapscript that does line thinning. It's a port of the !ArcView thinning script. A bit slow but seems to work fine. 56 56 57 57 * [wiki:PerlMapScriptExamples35ex14 query_points.pl] submitted by Eric Bridger <eric@gomoos.org> … … 63 63 A new and improved version of query_points.pl. Shows how to create a dynamic point layer which responds to queryByPoint() and will return your numeric database key values. 64 64 65 bound add.pl 65 * [wiki:PerlMapScriptExamples35ex15 bound_add.pl] 66 66 67 67 Given the name of an existing polygon shapefile this routine will add 4 fields to the dbf file for the least bounding rectangle for each polygon and populate those fields.
