| 1 | = Setting up !MapServer/!MapScript version 3.6 on !RedHat 7.3 = |
| 2 | |
| 3 | NOTE: These instructions were based on [wiki:PHPMapScript72 Detailed instructions to compile/install PHP MapScript 3.6 on RedHat 7.2]. |
| 4 | |
| 5 | == Objective == |
| 6 | |
| 7 | Configure a brand new RedHat 7.3 server to host MapServer-based apps: |
| 8 | |
| 9 | - MapServer 3.6 (WMS) |
| 10 | - PHPMapScript 3.6 |
| 11 | - GMap |
| 12 | |
| 13 | == Server Information == |
| 14 | |
| 15 | We start with a clean !RedHat 7.3 install, configured with Apache preinstalled but no PHP. |
| 16 | |
| 17 | Source packages will be compiled under "/home/src" and installed in /usr/local |
| 18 | |
| 19 | Web Server installed under /var/www: |
| 20 | |
| 21 | DocRoot = /var/www/html |
| 22 | CGI dir = /var/www/cgi-bin |
| 23 | Config = /etc/httpd/conf |
| 24 | |
| 25 | !MapServer apps will be installed under /home/msapps using a logical link from /var/www/html/ -> /home/msapps/ |
| 26 | |
| 27 | == List of required files or packages == |
| 28 | |
| 29 | proj-4.4.5.tar.gz |
| 30 | proj-nad27-1.1.tar.gz |
| 31 | |
| 32 | gdal-1.1.7.tar.gz |
| 33 | |
| 34 | gd-2.0.7gif.tar.gz |
| 35 | |
| 36 | libwww-5.3.2-20011211.tar.gz (CVS version as of 2001-12-11) |
| 37 | |
| 38 | php-4.2.3.tar.gz |
| 39 | |
| 40 | mapserver-3.6.3.tar.gz |
| 41 | |
| 42 | ... and just for testing: |
| 43 | |
| 44 | gmap-ms36.tar.gz |
| 45 | |
| 46 | == COMPILE/INSTALL PROJ-4 == |
| 47 | {{{ |
| 48 | $ cd /home/src |
| 49 | $ tar xzvf ~/arch/proj-4.4.5.tar.gz |
| 50 | $ cd proj-4.4.5/nad |
| 51 | $ tar xzvf ~/arch/proj-nad27-1.1.tar.gz |
| 52 | $ cd .. |
| 53 | $ ./configure |
| 54 | $ make |
| 55 | $ sudo make install |
| 56 | $ cd .. |
| 57 | }}} |
| 58 | ... also copy the custom "epsg" file (with EPSG:42xxx projections: http://www2.dmsolutions.ca/mapserver/dl/proj4-epsg-with-42xxx.zip): |
| 59 | {{{ |
| 60 | $ sudo cp ~/arch/epsg /usr/local/share/proj/epsg |
| 61 | }}} |
| 62 | ... edit /etc/ld.so.conf and add /usr/local/lib, then run |
| 63 | {{{ |
| 64 | $ sudo /sbin/ldconfig |
| 65 | }}} |
| 66 | == COMPILE/INSTALL GDAL == |
| 67 | {{{ |
| 68 | $ tar xzvf ~/arch/gdal-1.1.7.tar.gz |
| 69 | $ cd gdal-1.1.7 |
| 70 | $ ./configure |
| 71 | $ make |
| 72 | $ sudo make install |
| 73 | $ cd .. |
| 74 | $ sudo /sbin/ldconfig |
| 75 | }}} |
| 76 | == COMPILE/INSTALL W3C-LIBWWW V5.3.2 == |
| 77 | |
| 78 | ... w3c-libwww version 5.3.2 with the latest fixes can be obtained only via CVS, but for this install, I've tared the copy that was previously downloaded and built on another server... it's simpler this way ;) (http://www2.dmsolutions.ca/mapserver/dl/misc/libwww-5.3.2-20011211.tar.gz) |
| 79 | {{{ |
| 80 | $ tar xzvf ~/arch/libwww-5.3.2-20011211.tar.gz |
| 81 | $ cd libwww |
| 82 | $ ./configure |
| 83 | $ make |
| 84 | $ sudo make install |
| 85 | $ cd .. |
| 86 | $ sudo /sbin/ldconfig |
| 87 | }}} |
| 88 | == COMPILE/INSTALL GD-2.0.7 (with GIF and TTF) == |
| 89 | |
| 90 | RH7.3 comes with a copy of gd-1.8.4 (without GIF) preinstalled. Since we want gd-2.0.7 with GIF (http://www.rime.com.au/gd/), we have to uninstall gd-devel-1.8.4-4.rpm and then install our new copy of gd under /usr/local/lib. This won't affect or break existing applications because removing the RPM only removes /usr/lib/libgd.so (logical link) and /usr/lib/libgd.a and the associated headers, but the physical file (libgd.so.1.8.4) will remain there for applications that came preinstalled on the RH system. |
| 91 | {{{ |
| 92 | $ sudo rpm -e gd-devel-1.8.4-4 |
| 93 | |
| 94 | $ tar xzvf ~/arch/gd-2.0.7gif.tar.gz |
| 95 | $ cd gd-2.0.7gif |
| 96 | |
| 97 | $ ./configure |
| 98 | $ make |
| 99 | $ sudo make install |
| 100 | $ cd .. |
| 101 | }}} |
| 102 | == COMPILE/INSTALL PHP 4 == |
| 103 | |
| 104 | Note: We want PHP to use our custom GD compiled with Freetype 1.3, but PHP won't detect freetype by default. For PHP to detect the freetype1 headers, we have to create a logical link in /usr/include: |
| 105 | {{{ |
| 106 | $ cd /usr/include |
| 107 | $ sudo ln -s freetype1/freetype freetype |
| 108 | }}} |
| 109 | ... then we can proceed with normal PHP configuration. |
| 110 | {{{ |
| 111 | $ tar xzvf ~/arch/php-4.2.3.tar.gz |
| 112 | $ cd php-4.2.3 |
| 113 | }}} |
| 114 | Compilation will fail unless two source files are corrected. Apparently the method free() was renamed to gd_free(). |
| 115 | |
| 116 | Modify ./ext/gd/gd.c |
| 117 | |
| 118 | Change line 1014 from io_ctx->free(io_ctx); to io_ctx->gd_free(io_ctx); |
| 119 | Change line 1017 from io_ctx->free(io_ctx); to io_ctx->gd_free(io_ctx); |
| 120 | Change line 1209 from io_ctx->free(io_ctx); to io_ctx->gd_free(io_ctx); |
| 121 | |
| 122 | Modify ./ext/gd/gd_ctx.c |
| 123 | |
| 124 | Change line 70 from ctx->free = _php_image_output_ctxfree; to ctx->gd_free = _php_image_output_ctxfree; |
| 125 | Change line 98 from ctx->free(ctx); to ctx->ctx->gd_free(ctx); |
| 126 | {{{ |
| 127 | $ ./configure --enable-shared --with-regex=system --with-gd \ |
| 128 | --with-ttf=/usr --enable-gd-native-ttf --with-jpeg-dir=/usr \ |
| 129 | --with-png-dir=/usr --with-zlib --enable-force-cgi-redirect \ |
| 130 | --enable-dbase --with-config-file-path=/etc/httpd/conf |
| 131 | |
| 132 | $ make |
| 133 | $ strip php |
| 134 | $ sudo make install |
| 135 | $ sudo cp php /var/www/cgi-bin/php |
| 136 | $ sudo cp php.ini-dist /etc/httpd/conf/php.ini |
| 137 | $ cd .. |
| 138 | }}} |
| 139 | ... edit /etc/httpd/conf/php.ini to set: |
| 140 | {{{ |
| 141 | ... |
| 142 | log_errors = On |
| 143 | ... |
| 144 | extension_dir = /usr/local/lib/php/extensions/ |
| 145 | ... |
| 146 | }}} |
| 147 | ... edit /etc/httpd/conf/httpd.conf |
| 148 | {{{ |
| 149 | # |
| 150 | # And for PHP 4.x, use: |
| 151 | # |
| 152 | ## |
| 153 | ## Commented-out... we bypass the PHP module and use PHP4 as |
| 154 | ## a CGI instead ... see below |
| 155 | ## |
| 156 | ## ... old config ... |
| 157 | ## |
| 158 | # <IfModule mod_php4.c> |
| 159 | # AddType application/x-httpd-php .php .php4 .php3 .phtml |
| 160 | # AddType application/x-httpd-php-source .phps |
| 161 | # </IfModule> |
| 162 | ## |
| 163 | ## New PHP 4 CGI config |
| 164 | ## |
| 165 | ## Use a different application type to bypass the PHP DSO |
| 166 | ## |
| 167 | AddType application/x-httpd-php4 .php4 .php3 .phtml .php |
| 168 | Action application/x-httpd-php4 /cgi-bin/php |
| 169 | }}} |
| 170 | Then restart the server using |
| 171 | {{{ |
| 172 | $ sudo /etc/rc.d/init.d/httpd restart |
| 173 | }}} |
| 174 | == COMPILE/INSTALL MAPSERVER == |
| 175 | {{{ |
| 176 | $ tar xzvf ~/arch/mapserver-3.6.3.tar.gz |
| 177 | $ cd mapserver-3.6.3 |
| 178 | $ ./configure --with-proj --with-wmsclient --with-libwww \ |
| 179 | --with-gdal --enable-runpath --with-php=../php-4.2.3 \ |
| 180 | --without-tiff --with-gd --enable-force-freetype1 \ |
| 181 | --enable-internal-ld-detect |
| 182 | |
| 183 | $ make |
| 184 | |
| 185 | $ cp mapserv /var/www/cgi-bin/mapserv_36 |
| 186 | $ sudo cp mapscript/php3/php_mapscript.so /usr/local/lib/php/extensions/php_mapscript_36.so |
| 187 | |
| 188 | $ cd /usr/local/lib/php/extensions |
| 189 | $ sudo ln -s php_mapscript_36.so php_mapscript.so |
| 190 | }}} |
| 191 | == Setup MapServer IMAGEDIR and cleanup script == |
| 192 | {{{ |
| 193 | $ sudo mkdir /tmp/ms_tmp |
| 194 | $ sudo chmod 777 /tmp/ms_tmp |
| 195 | }}} |
| 196 | ... also add the commands above to /etc/rc.d/rc.local as well to recreate the directory when the system reboots, after a /tmp cleanup... |
| 197 | |
| 198 | ... create a logical link for the ms_tmp directory on the web server |
| 199 | {{{ |
| 200 | $ cd /var/www/html |
| 201 | $ ln -s /tmp/ms_tmp ms_tmp |
| 202 | }}} |
| 203 | ... create "/etc/cron.daily/ms_clear_tmp.sh" ... you can also place the file in /etc/cron.hourly/ for busier sites... |
| 204 | {{{ |
| 205 | #! /bin/sh |
| 206 | # |
| 207 | # MapServer temporary file cleanup - run daily by cron |
| 208 | # |
| 209 | # Flush all files from /tmp/ms_tmp older than 6 hours (360 minutes) |
| 210 | # |
| 211 | find /tmp/ms_tmp -name "*.*" -amin +360 -exec rm -f {} \; |
| 212 | exit 0 |
| 213 | }}} |
| 214 | == SETUP GMAP DEMO == |
| 215 | |
| 216 | Install a copy of the latest GMap demo to test our installation: |
| 217 | {{{ |
| 218 | $ cd /home/msapps |
| 219 | $ tar xzvf ~/arch/gmap-ms36.tar.gz |
| 220 | }}} |
| 221 | ... create a link from the htdocs directory to the application's htdoc: |
| 222 | {{{ |
| 223 | $ cd /var/www/html/ |
| 224 | $ ln -s /home/msapps/gmap/htdocs gmap |
| 225 | }}} |
| 226 | ... modify the .map file to provide the complete pathname to the FontSet: |
| 227 | |
| 228 | Modify /home/msapps/gmap/htdocs/gmap75.map |
| 229 | |
| 230 | Change the FONTSET line (14) to FONTSET /home/msapps/gmap/etc/fonts.txt |
| 231 | |
| 232 | You should now be able to run GMap at |
| 233 | |
| 234 | http://your.host.name/gmap/gmap75.phtml |
