79 | | After you restart Apache, any script with the .phtml extension in the /var/www/html/mapscript directory will execute successfully as a CGI (if you try accessing through a browser a .phtml file in another directory a 404 error appears), and all files with .php extension (in any directory) will be interpreted with the DSO module. You can generalize this procedure so any script with .phtml extension executes as a CGI, adjusting the place where you put the link to the executable and using, for instance, the ScriptAlias directive (there are many ways to do it and are dependant on your particular configuration). |
| 79 | After you restart Apache, any script with the .phtml extension in the /var/www/html/mapscript directory will execute successfully as a CGI (if you try accessing through a browser a .phtml file in another directory a 404 error appears), and all files with .php extension (in any directory) will be interpreted with the DSO module. You can generalize this procedure so any script with .phtml extension executes as a CGI, adjusting the place where you put the link to the executable and using, for instance, the !ScriptAlias directive (there are many ways to do it and are dependant on your particular configuration). |
