| 1 | = PHP MapScript Topics = |
| 2 | |
| 3 | == Build and Installation Notes == |
| 4 | |
| 5 | 1. LinuxBuild |
| 6 | 2. WindowsBuild |
| 7 | 3. PHP MapScript 3.5 and up requires PHP configured as a CGI |
| 8 | 4. DebianLinux |
| 9 | 5. Detailed instructions to compile/install PHP MapScript 3.6 on RedHat 7.2 |
| 10 | 6. Detailed instructions to compile/install PHP MapScript 3.6 on RedHat 7.3 |
| 11 | 7. Detailed instructions to compile/install PHP MapScript 3.6 on RedHat 8.0 |
| 12 | 8. Detailed instructions to compile/install PHP MapScript 4.0 on RedHat 9 |
| 13 | 9. OS X Detailed compile/install instructions: See http://home.nc.rr.com/wwheaton/ |
| 14 | 10. Building and Debugging PHP MapScript on Linux |
| 15 | 11. PHP binaries and PHPMapScript should use the exact same libraries |
| 16 | 12. PHP Mapscript setup on Fedora Core |
| 17 | |
| 18 | == Documentation == |
| 19 | |
| 20 | 1. http://mapserver.gis.umn.edu/doc/phpmapscript-class-guide.html |
| 21 | 2. http://mapserver.gis.umn.edu/doc/phpmapscript-install-howto.html |
| 22 | 3. http://www2.dmsolutions.ca/mapserver/php_mapscript/index.html |
| 23 | 4. http://www2.dmsolutions.ca/mapserver/php_mapscript/php_mapscript_faq.html |
| 24 | |
| 25 | == Examples == |
| 26 | |
| 27 | 1. Flowchart of typical PHP/Mapscript application |
| 28 | 2. Code snippet to map image XY to map XY |
| 29 | 3. Sample code about how to add a dynamic point to a map |
| 30 | 4. Sample code about how to add a dynamic line to a map |
| 31 | 5. Outputting maps to PDF |
| 32 | 6. PHP MapScript 3.6 - How to create and use dynamic legends / layer controls |
