Changes between Version 2 and Version 3 of PHPBuildDebugLinux
- Jan 27, 2009, 9:17:40 AM (15 years ago)
PHPBuildDebugLinux
v2 v3 56 56 5- Copy php_mapscript.so to your extensions_dir 57 57 58 6- Make sure all libs used in your !MapServer build are included in your runtime library path. See the PHP MapScript install FAQ about this common problem: http://www.mapserver.org/installation/php.html#faq-common-problems58 6- Make sure all libs used in your !MapServer build are included in your runtime library path. See the PHP !MapScript install FAQ about this common problem: http://www.mapserver.org/installation/php.html#faq-common-problems 59 59 60 60 7- You're ready to use dl("php_mapscript.so"); to load and use PHP MapScript in your PHP apps.
