| 1 | = Building and Debugging PHP MapScript on Linux = |
| 2 | |
| 3 | Stephen Woodbridge wrote: |
| 4 | {{{ |
| 5 | > I have finally gotten around to trying to debug the |
| 6 | > PHP3/Mapscript? problem I was having. You said I should |
| 7 | > build PHP/Mapscript? as a static php CGI executable so I |
| 8 | > can run it in gdb. |
| 9 | }}} |
| 10 | Actually, I meant compile PHP as a CGI executable instead of as an Apache DSO. And then you still compile PHP !MapScript the same way, as a php_mapscript.so file that will be loaded by PHP at runtime. |
| 11 | |
| 12 | Once you're all setup, you can debug a PHP script that crashes using the 'php' CGI executable in gdb with: |
| 13 | {{{ |
| 14 | $ gdb ./php |
| 15 | ... |
| 16 | (gdb) run /path/to/test.php |
| 17 | ... |
| 18 | }}} |
| 19 | Here is the fun part: If you need to setup a breakpoint inside php_mapscript.so then you have to: |
| 20 | |
| 21 | - First set a breakpoint in php_dl() |
| 22 | - start the program, when it reaches php_dl(), type "finish" to let |
| 23 | php_dl() finish its execution |
| 24 | - debugger will stop again at the end of php_dl(), after |
| 25 | php_mapscript.so is loaded... then you can set breakpoints anywhere |
| 26 | in php_mapscript.so and enjoy gdb! :) |
| 27 | - Make sure you disable all breakpoints before re-running the program |
| 28 | or gdb will keep complaining about them |
| 29 | |
| 30 | There may be ways to automate this in gdb but I never looked into that any further... I welcome suggestions. |
| 31 | {{{ |
| 32 | > All the documentation only talks about building it as a DSO module for |
| 33 | > apache. Can you send me a link or have someone add it to Wiki? I think |
| 34 | > this would be a great help to aid others that might want to work with |
| 35 | > PHP3 and Mapscript. |
| 36 | > |
| 37 | }}} |
| 38 | The answer to this question has been moved to a separate PHPMapScriptCGI page. |
| 39 | {{{ |
| 40 | > Also have you guys posted documentation on how to build Mapscript for |
| 41 | > PHP4 and !MapServer 3.5? on Wiki? |
| 42 | > |
| 43 | }}} |
| 44 | Nothing special to say there... !MapServer's configure takes care of it all on most platforms... here are some detailed steps (hopefully I didn't forget anything): |
| 45 | |
| 46 | 1- Compile and install PHP as a CGI as described above |
| 47 | |
| 48 | 2- Run configure in your mapserver dir. with the --with-php switch: |
| 49 | |
| 50 | ./configure --with-php=/path/to/php-src-that-you-just-compiled ... |
| 51 | |
| 52 | 3- run 'make', that will automagically build mapserv, etc. ... and php_mapscript.so in mapserver/mapscript/php3 |
| 53 | |
| 54 | 4- Edit your php.ini and make sure extensions_dir is set to point to a valid location (e.g. /usr/local/lib/php4) |
| 55 | |
| 56 | 5- Copy php_mapscript.so to your extensions_dir |
| 57 | |
| 58 | 6- Make sure all libs used in your MapServer build are included in your runtime library path. See the PHP MapScript install FAQ about this common problem: http://mapserver.gis.umn.edu/doc/phpmapscript-install-howto.html#d41e543 |
| 59 | |
| 60 | 7- You're ready to use dl("php_mapscript.so"); to load and use PHP MapScript in your PHP apps. |
| 61 | |
| 62 | See also the PHPMapScript-install-HOWTO for more info: http://www.mapserver.org/installation/php.html |
