Changes between Version 8 and Version 9 of MapServerOGCCITEComplianceWFS110Notes
- Feb 8, 2010, 3:22:35 PM (14 years ago)
v8 v9 19 19 |||| DF tc3.4|| Invalid post request (without version) || It is expecting back an excpetion a WFS exception report but MapServer will not be able to generate this since It is not only a WFS server|| 20 20 |||| DF tc3.5|| Invalid post request (with invalid service=FDO) || It is expecting back an excpetion a WFS exception report but MapServer will not be able to generate this since It is not only a WFS server|| 21 |||| DF tc11.1|| The expression '(//xsd:element/@name = 'PrimitiveGeoFeature') and (//xsd:element/@name = 'AggregateGeoFeature') and (//xsd:element/@name = 'EntitéGénérique')' is false.|| This need to be solved with encoding somehow(for now mapfile is saved as UTF, ows_encoding is set to UTF-8 and wfs11.c capabilities do not use the map level encoding to dump the xml (use always xmlDocDumpFormatMemoryEnc(psDoc, &buffer, &size, "ISO-8859-1", 1);||21 |||| DF tc11.1|| The expression '(//xsd:element/@name = 'PrimitiveGeoFeature') and (//xsd:element/@name = 'AggregateGeoFeature') and (//xsd:element/@name = 'EntitéGénérique')' is false.|| bug http://trac.osgeo.org/mapserver/ticket/3297. Map file is saved using encoding ISO-8859-1|| 22 22 ||AY || DF Test wfs:DescribeFeatureType-output-format-default || 4tests: The MIME returned for a DescribeFeatureType request where no specific output format is requested is "text/xml; subtype=gml/3.1.1 ;;;; When output format XMLSCHEMA is supported, the MIME returned for a DescribeFeatureType? request where the output format requested is XMLSCHEMA is "text/xml; subtype=gml/2.1.2". ;;;; When output format "text/xml; subtype=gml/2.1.2" is supported, the MIME returned for a DescribeFeatureType? request where the output format requested is "text/xml; subtype=gml/2.1.2" is "text/xml; subtype=gml/2.1.2". ;;;;; The MIME returned for a DescribeFeatureType? request where the output format requested is "text/xml; subtype=gml/3.1.1" is "text/xml; subtype=gml/3.1.1". " || Fixed: http://trac.osgeo.org/mapserver/ticket/3294|| 23 23 ||NS||GF Test wfs:GetFeature-output-format-default||The MIME returned for a GetFeature request where no specific output format is requested is "text/xml; subtype=gml/3.1.1" ||This need to be solved: http://trac.osgeo.org/mapserver/ticket/3295||
