Changes between Version 4 and Version 5 of MapServerOGCCITEComplianceWFS110Notes
- Feb 8, 2010, 11:07:10 AM (14 years ago)
v4 v5 21 21 |||| DF tc11.1|| The expression '(//xsd:element/@name = 'PrimitiveGeoFeature') and (//xsd:element/@name = 'AggregateGeoFeature') and (//xsd:element/@name = 'EntitéGénérique')' is false.|| This need to be solved with encoding somehow(for now mapfile is saved as UTF, ows_encoding is set to UTF-8 and wfs11.c capabilities do not use the map level encoding to dump the xml (use always xmlDocDumpFormatMemoryEnc(psDoc, &buffer, &size, "ISO-8859-1", 1);|| 22 22 ||AY || DF Test wfs:DescribeFeatureType-output-format-default || The MIME returned for a DescribeFeatureType request where no specific output format is requested is "text/xml; subtype=gml/3.1.1" || This need to be solved: http://trac.osgeo.org/mapserver/ticket/3294|| 23 ||NS||GF || ||||23 ||NS||GF Test wfs:GetFeature-output-format-default||The MIME returned for a DescribeFeatureType request where no specific output format is requested is "text/xml; subtype=gml/3.1.1" ||This need to be solved: http://trac.osgeo.org/mapserver/ticket/3295|| 24 24 |||| || |||| 25 25
