Changes between Version 52 and Version 53 of MapServerOGCCITECompliance
- Aug 6, 2009, 1:00:43 PM (15 years ago)
v52 v53 227 227 228 228 - Note 229 The re is a mistake in the capabilities schema found on http://schemas.opengis.net/wcs/1.0.0/wcsCapabilities.xsd. The relevant parts of the emails exchange are pasted below. To solve this issue, the second solution proposed by Alexandre Robin was applied. So the capabilities schema was changed as follow.229 The purpose of this note is to keep a record of what need to be done in order to have a valid capabilities schema since the official Web schema is not updated with the proposed solution. There is a mistake in the capabilities schema found on http://schemas.opengis.net/wcs/1.0.0/wcsCapabilities.xsd. The relevant parts of the emails exchange are pasted below. To solve this issue, the second solution proposed by Alexandre Robin was applied. So the capabilities schema was changed as follow. 230 230 231 231 {{{
