Changes between Version 40 and Version 41 of MapServerOGCCITECompliance
- Aug 3, 2009, 1:25:40 PM (15 years ago)
v40 v41 16 16 The OGC WFS 1.0.0 compliance tests suite uses dual namespaces in the test requests. Since MapServer does not support multiple namespaces in the same map file, the tests listed in the table below failed. After some discussion on the CITE mailing list (http://lists.opengeospatial.org/pipermail/cite-forum/2008-January/000086.html), it comes out that if a WFS server does not support multiple namespaces, the tests suite may be run as many time as there are different namespaces. Then the test results could be combined to satisfy the tests suite. For that, we need to create two different tests sessions: the first one set up with the "cdf" namespace and the second one, with the "cgf" namespace, and run them separately. 17 17 18 {{{ 19 Norm, 20 21 After looking into this, I believe that you are correct. The Test Scripts are too limiting and should not fail implementations that do not support multiple namespaces. 22 23 Please do submit your test results with the below notice. As long as the tests are all complete, I can review the test results with the below test failures. 24 25 Greg Buehler 26 }}} 18 27 The "wfs_namespace_prefix" and "wfs_namespace_uri" metadatas have to be modified to follow the current tests session that is based on the namespace. The following table describe the settings used in the tests. 19 28
