Changes between Version 2 and Version 3 of MapRotation
- 01/29/09 12:19:54 (4 years ago)
MapRotation
v2 v3 101 101 102 102 * valid projectionObj's are required on all layers and the map even though they may well all match exactly. In fact, pointless reprojection operations are going to take place. 103 * In MapServer "cgi" mode there is no way to drive the rotation from the URL (Steve plans to fix this).104 * In MapServer "cgi" mode there is no way to substitute the currently render rotation into the returned HTML form for a given render. There needs to be a template variable for rotation.103 * In !MapServer "cgi" mode there is no way to drive the rotation from the URL (Steve plans to fix this). 104 * In !MapServer "cgi" mode there is no way to substitute the currently render rotation into the returned HTML form for a given render. There needs to be a template variable for rotation. 105 105 * Query operations do not "know" about rotation on the source raster, and so can't properly transform pixel/line coordinates on the last rendered map into georeferenced coordinates for the query. 106 106 * There is no mapscript mechanism to get the rotation angle from a map.
