Changes between Version 15 and Version 16 of GSoC_SVG_Symbols_report_20090606
- Jun 6, 2009, 10:38:36 AM (15 years ago)
v15 v16 24 24 25 25 26 1. Still need research on how to successfully render svg objects to MapServer.26 1. Still need research on how to successfully render svg objects to MapServer. 27 27 28 2. I should continously survey on the new rendering API,how to use it.28 2. I should continously survey on the new rendering API,how to use it. 29 29 30 3. How can we replace all the past renderers with the ones provided by cairo.30 3. How can we replace all the past renderers with the ones provided by cairo. 31 31 32 4. Huge research needed ,on how to use Cairo's features for implementing svg symbolization,try getting familiar with cairo's sources.32 4. Huge research needed ,on how to use Cairo's features for implementing svg symbolization,try getting familiar with cairo's sources. 33 33 34 5.I still need to spend more and more time for adding this feature successfully to MapServer 34 5. Execute some simple example Svg files using Cairo surfaces 35 36 6. I still need to spend more and more time for adding this feature successfully to MapServer 35 37 36 38 Regards
