Changes between Version 5 and Version 6 of FAQ
Jan 27, 2009, 10:41:15 AM (15 years ago)
jmckenna
  • FAQ
    v5 v6
    3333  * [http://www.mapstorer.org/ MapStorer] can also be used with a database backend to manage mapfiles
    3434
    35 == Anytime I put numbers in the MAXSCALEDENOM? / MINSCALEDENOM?, the layers are not displayed at all. I have put numbers of varying ranges in, but no luck. Any ideas? ==
     35== Anytime I put numbers in the MAXSCALEDENOM / MINSCALEDENOM, the layers are not displayed at all. I have put numbers of varying ranges in, but no luck. Any ideas? ==
    3636
    3737Try putting a [scale] tag in your template to view the range of scale values that your map produces as you zoom in and out. This will help you in figuring the numbers to use as minscaledenom and maxscaledenom.
