Changes between Version 1 and Version 3 of Ticket #2180
- Jul 27, 2007, 10:37:50 AM (17 years ago)
Ticket #2180
- Property Status assigned → closed
- Property Resolution → fixed
Ticket #2180 – Description
v1 v3 1 This patch fixes a quite annoying bug that was explained by Jerome Martin (see the 2 original thread : 1 Producing non-square pixels or reprojected results with MapServer WCS does not work with tileindexed layers. The issue is described in the email: 2 3 3 http://lists.umn.edu/cgi-bin/wa?A2=ind0702&L=mapserver-users&T=0&F=&S=&P=852) 4 4 5 Now, I can make GetCoverage requests on a tileindex of DTED files with 6 resolutions (or dimensions) not necesseraly a multiple of the original 7 resolution, or into another projection system. 5 With the patch, I can make GetCoverage requests on a tileindex of DTED files with resolutions (or dimensions) not necesseraly a multiple of the original resolution, or into another projection system. 8 6 9 The fix consists of adding the following lines after 10 msMapComputeGeotransform, as it's done in mapdraw.c 7 The fix consists of adding the following lines after msMapComputeGeotransform, as it's done in mapdraw.c 11 8 12 9 {{{
