Here is an idea: instead of adding a new autoanglealgorithm member in the labelObj as was proposed in the auto2.tar.gz patch, we could get rid of autoangle and autofollow and combine all of them into a single label->anglemode member with the following possible values:
- 0, the default means that the angle value is either static or bound to an attribute
- MS_AUTO
- MS_AUTO2 (the new algorithm)
- MS_FOLLOW
Steve, do you expect any problem with that approach? I can take this ticket if you want, just reassign to me.
