Changes between Version 3 and Version 4 of maestro/UserGuides/VectorLayerEditor
Jan 22, 2013 5:40:27 PM (5 years ago)
davidwilhelmsson
Fix broken image links
  • maestro/UserGuides/VectorLayerEditor
    v3 v4
    66
    77You should new see the following dialog:[[BR]]
    8 [[Image(http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Screenshots/Userguide/EmptyLayer.png?format=raw)]]
     8[[Image(http://trac.osgeo.org/mapguide/browser/branches/maestro-2.x/Screenshots/Userguide/EmptyLayer.png?format=raw)]]
    1010Now browse to an existing !FeatureSource. Since this page is about vector data, make sure you don't select a raster layer. Once you have selected a !FeatureSource, your display should look like this:[[BR]]
    11 [[Image(http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Screenshots/Userguide/LayerStartup.png?format=raw)]]
     11[[Image(http://trac.osgeo.org/mapguide/browser/branches/maestro-2.x/Screenshots/Userguide/LayerStartup.png?format=raw)]]
    1212
    1313=== Resource Settings ===
    5757
    5858The core layer editor looks like this:[[BR]]
    59 [[Image(http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Screenshots/Userguide/layerEditorScales.png?format=raw)]]
     59[[Image(http://trac.osgeo.org/mapguide/browser/branches/maestro-2.x/Screenshots/Userguide/layerEditorScales.png?format=raw)]]
    6060
    6161The three buttons at the top can be used to add a new blank scale range, delete a scale range, and insert a copy of the currently selected scale range. The fourth last button can be used to make the editor fill the entire screen.
