Changes between Initial Version and Version 1 of maestro/MaestroAPI/2.xSamples
Nov 22, 2011 4:00:18 AM (6 years ago)
jng
  • maestro/MaestroAPI/2.xSamples
     1= Maestro API 2.x samples =
     3This page showcases code samples using the 2.x version of the Maestro API
     5 *  '''[wiki:maestro/MaestroAPI/samples/RuntimeMap Utilizing RuntimeMap via Maestro API]''' - a short example of getting to !RuntimeMap instance.
     6 *  '''[wiki:maestro/MaestroAPI/samples/AddInitialLayer Adding a layer before startup via Maestro API]''' - an example of how to add a layer to map before the viewer loads.
     7 *  '''[wiki:maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout Creating a temporary WebLayout with customized zoom]''' - shows how to modify an existing !WebLayout to select the initial zoom level.
     8 *  '''[wiki:maestro/MaestroAPI/samples/ModifyLayerFilter Modifying the filter on a layer]''' - shows how to modify the filter on a layer for the current user.
     9 *  '''[wiki:maestro/MaestroAPI/samples/IterateLayerRules Examining all styles defined in a layer]''' - a template for examining all layer styles in a !LayerDefinition.
     10 *  '''[wiki:maestro/MaestroAPI/samples/QueryFeatureSource Query Features with a filter]''' - an example of how to read features from MapGuide.
     11 *  '''[wiki:maestro/MaestroAPI/samples/BrandNewSample Add your cool sample here]''' You must be logged in with an [http://www.osgeo.org/osgeo_userid/ OSGeo ID] before you can edit the page.
