Changes between Version 48 and Version 49 of maestro/Downloads
- Nov 16, 2009, 9:34:28 AM (14 years ago)
maestro/Downloads
v48 v49 42 42 43 43 This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. 44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r43 26.msi Installer r4326]45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r43 26.zip Binaries r4326]44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4347.msi Installer r4347] 45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4347.zip Binaries r4347] 46 46 The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code. 47 47 48 r43 26has the following fixes and additions to 1.0.9:48 r4347 has the following fixes and additions to 1.0.9: 49 49 * Enabled editing of permissions on the root node. 50 50 * Fixed a bug with creating a package from the entire site. … … 94 94 * Fixed a disabled button in the Expression Editor (r4208) 95 95 * French translation by Pierre Cardinal (r4326) 96 * Fixed various problems with MgCooker (r4347) 97 * Added methods to deal with the selection in a runtime map, MaestroAPI (r4347) 98 * Added a method to duplicate resources (r4347) 99 * Added option to add multiple layers to a map (r4347) 100 * Added Font Symbol support for points on layers, thanks to Crispin, 1Spatial (r4347) 96 101 97 102 == Previous releases ==
