Changes between Version 43 and Version 44 of maestro/Downloads
- Aug 19, 2009, 1:17:07 PM (15 years ago)
maestro/Downloads
v43 v44 42 42 43 43 This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. 44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4 099.msi Installer r4099]45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4 099.zip Binaries r4099]44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4164.msi Installer r4164] 45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4164.zip Binaries r4164] 46 46 The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code. 47 47 48 r4 099has the following fixes and additions to 1.0.9:48 r4164 has the following fixes and additions to 1.0.9: 49 49 * Enabled editing of permissions on the root node. 50 50 * Fixed a bug with creating a package from the entire site. … … 85 85 * Fixed issue with deleting subgroups in MapDefinition (r4099) 86 86 * Vastly improved the Expression Editor (thank to Jackie) (r4099) 87 * Added a theme generator with color brewer support (r4163) 88 * Fixed problems with shortcuts in installer (r4164) 87 89 88 90 == Previous releases ==
