Changes between Version 33 and Version 34 of maestro/Downloads
- Mar 7, 2009, 4:02:04 AM (15 years ago)
maestro/Downloads
v33 v34 39 39 == Preview releases == 40 40 This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. 41 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3 691.msi Installer r3691]42 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3 691.zip Binaries r3691]41 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3705.msi Installer r3705] 42 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3705.zip Binaries r3705] 43 43 The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code. 44 44 45 r3 691has the following fixes and additions to 1.0.9:45 r3705 has the following fixes and additions to 1.0.9: 46 46 * Enabled editing of permissions on the root node. 47 47 * Fixed a bug with creating a package from the entire site. … … 65 65 * Folders and resources with dots (.) and slashes (/) are now shown correctly. 66 66 * Added a resource validator to check items for common errors 67 * Fixed a collision with unsaved items, and the validator 67 68 68 69 == Previous releases ==
