Changes between Version 30 and Version 31 of maestro/Downloads
Show
01/22/09 12:07:43 (4 years ago)
ksgeograf
  • maestro/Downloads
    v30 v31
    3939== Preview releases ==
    4040This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there.
    41  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3520.msi Installer r3520]
    42  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3520.zip Binaries r3520]
     41 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3558.msi Installer r3558]
     42 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3558.zip Binaries r3558]
    4343The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code.
    4444
    45 r3520 has the following fixes and additions to 1.0.9:
     45r3558 has the following fixes and additions to 1.0.9:
    4646 * Enabled editing of permissions on the root node.
    4747 * Fixed a bug with creating a package from the entire site.
    5959 * [wiki:maestro/MgCooker MgCooker] is part of the installation and avalible on maps
    6060 * Fixed a bug with scale range display on raster layers
     61 * Better display of actual data on previews
    6162
    6263== Previous releases ==
