Changes between Version 16 and Version 17 of maestro/Downloads
- Aug 23, 2008, 3:25:59 AM (16 years ago)
maestro/Downloads
v16 v17 39 39 == Preview releases == 40 40 This releases may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. 41 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r32 70.msi Installer r3270]42 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r32 70.zip Binaries r3270]41 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3285.msi Installer r3285] 42 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3285.zip Binaries r3285] 43 43 The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code. 44 44 45 r32 70has the following fixes and additions to 1.0.8:45 r3285 has the following fixes and additions to 1.0.8: 46 46 * Fixed a bug if the username is "Administrator" and the password is "admin", the OK button would be disabled 47 47 * Fixed a bug with building Gdal composite data config files 48 48 * Fixed a folder case problem (bug on Linux only) 49 49 * Added a menu to create and restore packages (MGP files) directly from Maestro 50 * Added a menu to edit packages 51 * Fixed an issue with character encoding of featuresources on layers 50 52 51 53 == Previous releases ==
