Changes between Version 3 and Version 4 of MapGuideRfc46
- Mar 14, 2008, 3:38:57 PM (16 years ago)
MapGuideRfc46
v3 v4 27 27 == Motivation == 28 28 29 The current MgSelectionBase::GenerateFilter() API returns a string representing a filter for a set of selected features. This filter string would look something like: "FeatId = 1109 OR FeatId = 1130 OR FeatId = 2065" such that each of the IDs of the selected features is explicitly specified. The string is then passed as the filter to MgFeatureService::SelectFeatures() to query the datastore. 29 The current MgSelectionBase::GenerateFilter() API returns a string representing a filter for a set of selected features. 30 31 {{{ 32 STRING MgSelectionBase::GenerateFilter(MgLayerBase* layer, CREFSTRING className); 33 }}} 34 35 This filter string would look something like: "FeatId = 1109 OR FeatId = 1130 OR FeatId = 2065" such that each of the IDs of the selected features is explicitly specified. The string is then passed as the filter to MgFeatureService::SelectFeatures() to query the datastore. 30 36 31 37 A selection can contain an unlimited number of features, which means that the filter will contain an unlimited number of OR conditions. However, most datastores have a finite number of OR's that can be supported, and some data sources, such as Access databases, are limited to a relatively small number or OR conditions. 32 38 33 Results can be unpredictable when the limit is exceeded due to buffer overruns and/or memory corruption leading to instability in the MapGuide Server. In an effort to improve stability, GenerateFilter() was modified to return a string representing a smaller subset of the total selected features.39 Results can be unpredictable when the limit is exceeded due to buffer overruns and/or memory corruption leading to instability in the MapGuide Server. In an effort to improve stability, GenerateFilter() was modified to return a string representing a smaller, but incomplete subset of the total selected features. 34 40 35 41 == Proposed Solution == 36 42 37 This is a more detailed description of the actual changes desired. The contents of this section will vary based on the target of the RFC, be it a technical change, website change, or process change. For example, for a technical change, items such as files, XML schema changes, and API chances would be identified. For a process change, the new process would be laid out in detail. For a website change, the files affected would be listed. 43 Exposing a new API to return a collection of smaller filters for a set of selected features will allow for querying of the datastore without compromising Server stability. 44 45 Proposed New API: 46 47 {{{ 48 MgStringCollection* MgSelectionBase::GenerateFilters(MgLayerBase* layer, CREFSTRING className, INT32 selectionSize); 49 }}} 50 51 The selectionSize parameter specifies the maximum size for each of the individual filters in the collection. For example, if selectionSize = 20, the maximum number of features represented by an individual filter is 20. The collection could contain an unlimited number of filters to handle an unlimited number of features. 38 52 39 53 == Implications == 40 54 41 This section allows discussion of the repercussions of the change, such as whether there will be any breakage in backwards compatibility, if documentation will need to be updated, etc. 55 Code that currently calls MgSelectionBase::GenerateFilter() should be updated to use MgSelectionBase::GenerateFilters() instead, and the caller will be required to process all the filters in the collection to correctly query the complete selection set. In places where a relatively small number of features are expected in a selection (i.e. less than the value specified by SelectionFilterSize in serverconfig.ini/webconfig.ini), MgSelectionBase::GenerateFilter() can still be safely used to return correct results. 56 57 This is a new API which will need to be documented. 42 58 43 59 == Test Plan == 44 60 45 How the proposed change will be tested, if applicable. New unit tests should be detailed here??? 61 Test existing APIs to ensure functionality does not change. Test NEW APIs functionality. 46 62 47 63 == Funding/Resources == 48 64 49 This section will confirm that the proposed feature has enough support to proceed. This would typically mean that the entity making the changes would put forward the RFC, but a non-developer could act as an RFC author if they are sure they have the funding to cover the change. 65 Autodesk to supply
