Changes between Version 31 and Version 32 of ConfigureGuide24Windows
- Sep 6, 2014, 10:43:32 AM (10 years ago)
v31 v32 50 50 * MapGuide Enterprise 2011 Server or Infrastructure Map Server 2012 = MapGuide 2.2 or older 51 51 * Autodesk Infrastructure Map Server 2013 = MapGuide 2.4 52 53 == Upgrade from MapGuide 2.(x-1) or older to 2.x == 54 55 If upgrading from an 2.(x-1) or older version to 2.x (for example, upgrading from 2.4 to 2.6), I recommend uninstalling the old version and rebooting to finish the uninstallation. This will clean up old IIS settings (such as the IIS application pool for the old version, for example, MapGuide24AppPool), leaving a clean IIS environment for installing the new version. Install the new version into the same folder as the old version to automatically inherit your existing repository (your repository is not touched during the uninstallation of the old version or installation of the new version). 56 57 Installing the new version without uninstalling the old version can result in invalid IIS settings that are a combination of the old and new versions and an inoperative MapGuide installation. If this occurs, uninstall MapGuide and manually remove all IIS settings in the manual configuration of IIS below for both the old and new versions to clean the IIS environment before reinstalling the new version. 52 58 53 59 == Install MapGuide ==
