Changes between Version 47 and Version 48 of ConfigureGuide22Windows
- Sep 13, 2010, 9:17:01 AM (14 years ago)
v47 v48 9 9 == IIS 7.x == 10 10 11 === = Install IIS 7.x to Windows 7 or Windows 2008 Server ====11 === Install IIS 7.x to Windows 7 or Windows 2008 Server === 12 12 13 13 By default, IIS 7 is not enabled under either Windows 7 or Windows 2008 Server. … … 19 19 Under Windows 2008 Server, go to Control Panel->Administrative Tools->Server Manager, in the left panel, select Role, in the right panel, click Add Roles->Server Roles->Web Server(IIS), click OK to add the selected Role, then in the left panel, select Feature, in the right panel, click Add Features, a window with available windows features should open. Find Web Server (IIS) Tools and check it, click OK to install this feature. 20 20 21 === PHP === 21 22 ==== Create registry key '''!IniFilePath'''. ==== 22 23 … … 77 78 78 79 '''Note:''' Some binary PHP installer may not have '''php5isapi.dll''', you can always find a compatible one for your PHP from the internet. [http://www.anindya.com/php-5-3-3-x64-64-bit-for-windows/ Here] is a place to get this file for PHP 5.3.x-x64 80 81 ==== ASP.NET ==== 82 79 83 80 84 == Apache2 ==
