Changes between Version 3 and Version 4 of TracReports
- Feb 1, 2017, 12:36:53 AM (7 years ago)
TracReports
v3 v4 1 = Trac Reports = 1 = Trac Reports 2 2 3 [[TracGuideToc]] 3 4 4 The Trac reports module provides a simple, yet powerful reporting facility 5 to present information about tickets in the Trac database. 6 7 Rather than have its own report definition format, TracReports relies on standard SQL 8 `SELECT` statements for custom report definition. 9 10 '''Note:''' ''The report module is being phased out in its current form because it seriously limits the ability of the Trac team to make adjustments to the underlying database schema. We believe that the [wiki:TracQuery query module] is a good replacement that provides more flexibility and better usability. While there are certain reports that cannot yet be handled by the query module, we intend to further enhance it so that at some point the reports module can be completely removed. This also means that there will be no major enhancements to the report module anymore.'' 11 12 ''You can already completely replace the reports module by the query module simply by disabling the former in [wiki:TracIni trac.ini]:'' 13 {{{ 5 The Trac reports module provides a simple, yet powerful reporting facility to present information about tickets in the Trac database. 6 7 Rather than have its own report definition format, TracReports relies on standard SQL `SELECT` statements for custom report definition. 8 9 '''Note:''' The report module is being phased out in its current form because it seriously limits the ability of the Trac team to make adjustments to the underlying database schema. We believe that the [wiki:TracQuery query module] is a good replacement that provides more flexibility and better usability. While there are certain reports that cannot yet be handled by the query module, we intend to further enhance it so that at some point the reports module can be completely removed. This also means that there will be no major enhancements to the report module anymore. 10 11 You can already completely replace the reports module by the query module simply by disabling the former in [wiki:TracIni trac.ini]: 12 {{{#!ini 14 13 [components] 15 14 trac.ticket.report.* = disabled 16 15 }}} 17 ''This will make the query module the default handler for the “View Tickets” navigation item. We encourage you to try this configuration and report back what kind of features of reports you are missing, if any.''16 This will make the query module the default handler for the “View Tickets” navigation item. We encourage you to try this configuration and report back what kind of features of reports you are missing, if any. 18 17 19 18 A report consists of these basic parts: … … 24 23 * '''Footer''' — Links to alternative download formats for this report. 25 24 26 == Changing Sort Order == 25 == Changing Sort Order 26 27 27 Simple reports - ungrouped reports to be specific - can be changed to be sorted by any column simply by clicking the column header. 28 28 29 29 If a column header is a hyperlink (red), click the column you would like to sort by. Clicking the same header again reverses the order. 30 30 31 == Changing Report Numbering == 31 == Changing Report Numbering 32 32 33 There may be instances where you need to change the ID of the report, perhaps to organize the reports better. At present this requires changes to the trac database. The ''report'' table has the following schema: 33 34 * id integer PRIMARY KEY … … 37 38 * description text 38 39 Changing the ID changes the shown order and number in the ''Available Reports'' list and the report's perma-link. This is done by running something like: 39 {{{ 40 update report set id=5 where id=3;41 }}} 42 Keep in mind that the integrity has to be maintained (i.e., ID has to be unique, and you don't want to exceed the max, since that's managed by SQLite someplace).40 {{{#!sql 41 UPDATE report SET id = 5 WHERE id = 3; 42 }}} 43 Keep in mind that the integrity has to be maintained, ie ID has to be unique, and you don't want to exceed the max, since that's managed by SQLite someplace. 43 44 44 45 You may also need to update or remove the report number stored in the report or query. 45 46 46 == Navigating Tickets == 47 == Navigating Tickets 48 47 49 Clicking on one of the report results will take you to that ticket. You can navigate through the results by clicking the ''Next Ticket'' or ''Previous Ticket'' links just below the main menu bar, or click the ''Back to Report'' link to return to the report page. 48 50 49 51 You can safely edit any of the tickets and continue to navigate through the results using the ''!Next/Previous/Back to Report'' links after saving your results, but when you return to the report, there will be no hint about what has changed, as would happen if you were navigating a list of tickets obtained from a query (see TracQuery#NavigatingTickets). 50 52 51 == Alternative Download Formats == 53 == Alternative Download Formats 54 52 55 Aside from the default HTML view, reports can also be exported in a number of alternative formats. 53 56 At the bottom of the report page, you will find a list of available data formats. Click the desired link to 54 57 download the alternative report format. 55 58 56 === Comma-delimited - CSV (Comma Separated Values) === 59 === Comma-delimited - CSV (Comma Separated Values) 60 57 61 Export the report as plain text, each row on its own line, columns separated by a single comma (','). 58 62 '''Note:''' The output is fully escaped so carriage returns, line feeds, and commas will be preserved in the output. 59 63 60 === Tab-delimited === 64 === Tab-delimited 65 61 66 Like above, but uses tabs (\t) instead of comma. 62 67 63 === RSS - XML Content Syndication === 68 === RSS - XML Content Syndication 69 64 70 All reports support syndication using XML/RSS 2.0. To subscribe to an RSS feed, click the orange 'XML' icon at the bottom of the page. See TracRss for general information on RSS support in Trac. 65 71 66 ---- 67 68 == Creating Custom Reports == 69 70 ''Creating a custom report requires a comfortable knowledge of SQL.'' 71 72 '''Note that you need to set up [TracPermissions#Reports permissions] in order to see the buttons for adding or editing reports.''' 73 74 A report is basically a single named SQL query, executed and presented by 75 Trac. Reports can be viewed and created from a custom SQL expression directly 76 in the web interface. 77 78 Typically, a report consists of a SELECT-expression from the 'ticket' table, 79 using the available columns and sorting the way you want it. 80 81 == Ticket columns == 72 == Creating Custom Reports 73 74 Creating a custom report requires a comfortable knowledge of SQL. 75 76 Note that you need to set up [TracPermissions#Reports permissions] in order to see the buttons for adding or editing reports. 77 78 A report is basically a single named SQL query, executed and presented by Trac. Reports can be viewed and created from a custom SQL expression directly in the web interface. 79 80 Typically, a report consists of a SELECT-expression from the 'ticket' table, using the available columns and sorting the way you want it. 81 82 == Ticket columns 83 82 84 The ''ticket'' table has the following columns: 83 85 * id … … 102 104 103 105 Example: '''All active tickets, sorted by priority and time''' 104 {{{ 105 SELECT id AS ticket, status, severity, priority, owner, 106 time AS created, summary FROM ticket 107 WHERE status IN ('new', 'assigned', 'reopened') 108 ORDER BY priority, time 109 }}} 110 111 112 == Advanced Reports: Dynamic Variables == 106 {{{#!sql 107 SELECT id AS ticket, status, severity, priority, owner, time AS created, summary 108 FROM ticket 109 WHERE status IN ('new', 'assigned', 'reopened') 110 ORDER BY priority, time 111 }}} 112 113 Dynamic variables can also be used in the report title and description (since 1.1.1). 114 115 == Advanced Reports: Dynamic Variables 116 113 117 For more flexible reports, Trac supports the use of ''dynamic variables'' in report SQL statements. 114 118 In short, dynamic variables are ''special'' strings that are replaced by custom data before query execution. 115 119 116 === Using Variables in a Query === 120 === Using Variables in a Query 121 117 122 The syntax for dynamic variables is simple, any upper case word beginning with '$' is considered a variable. 118 123 119 124 Example: 120 {{{ 125 {{{#!sql 121 126 SELECT id AS ticket,summary FROM ticket WHERE priority=$PRIORITY 122 127 }}} 123 128 124 To assign a value to $PRIORITY when viewing the report, you must define it as an argument in the report URL, leaving out the leading '$'. 125 126 Example: 129 To assign a value to $PRIORITY when viewing the report, you must define it as an argument in the report URL, leaving out the leading '$': 127 130 {{{ 128 131 http://trac.edgewall.org/reports/14?PRIORITY=high 129 132 }}} 130 133 131 To use multiple variables, separate them with an '&'. 132 133 Example: 134 To use multiple variables, separate them with an '&': 134 135 {{{ 135 136 http://trac.edgewall.org/reports/14?PRIORITY=high&SEVERITY=critical 136 137 }}} 137 138 138 139 === !Special/Constant Variables === 139 === !Special/Constant Variables 140 140 141 There is one dynamic variable whose value is set automatically (the URL does not have to be changed) to allow practical reports. 141 142 142 143 * $USER — Username of logged in user. 143 144 144 Example (''List all tickets assigned to me''):145 {{{ 145 Example: List all tickets assigned to me: 146 {{{#!sql 146 147 SELECT id AS ticket,summary FROM ticket WHERE owner=$USER 147 148 }}} 148 149 149 150 151 == Advanced Reports: Custom Formatting == 152 Trac is also capable of more advanced reports, including custom layouts, 153 result grouping and user-defined CSS styles. To create such reports, we'll use 154 specialized SQL statements to control the output of the Trac report engine. 155 156 === Special Columns === 157 To format reports, TracReports looks for 'magic' column names in the query 158 result. These 'magic' names are processed and affect the layout and style of the 159 final report. 160 161 === Automatically formatted columns === 150 == Advanced Reports: Custom Formatting 151 152 Trac is also capable of more advanced reports, including custom layouts, result grouping and user-defined CSS styles. To create such reports, we will use specialized SQL statements to control the output of the Trac report engine. 153 154 === Special Columns 155 156 To format reports, TracReports looks for 'magic' column names in the query result. These 'magic' names are processed and affect the layout and style of the final report. 157 158 === Automatically formatted columns 159 162 160 * '''ticket''' — Ticket ID number. Becomes a hyperlink to that ticket. 163 161 * '''id''' — same as '''ticket''' above when '''realm''' is not set … … 168 166 169 167 '''Example:''' 170 {{{ 168 {{{#!sql 171 169 SELECT id AS ticket, created, status, summary FROM ticket 172 170 }}} … … 176 174 See trac:wiki/CookBook/Configuration/Reports for some example of creating reports for realms other than ''ticket''. 177 175 178 === Custom formatting columns === 176 === Custom formatting columns 177 179 178 Columns whose names begin and end with 2 underscores (Example: '''`__color__`''') are 180 179 assumed to be ''formatting hints'', affecting the appearance of the row. … … 197 196 198 197 '''Example:''' ''List active tickets, grouped by milestone, group header linked to milestone page, colored by priority'' 199 {{{ 198 {{{#!sql 200 199 SELECT p.value AS __color__, 201 200 t.milestone AS __group__, 202 201 '../milestone/' || t.milestone AS __grouplink__, 203 202 (CASE owner WHEN 'daniel' THEN 'font-weight: bold; background: red;' ELSE '' END) AS __style__, 204 t.id AS ticket, summary 205 FROM ticket t,enum p 206 WHERE t.status IN ('new', 'assigned', 'reopened') 207 AND p.name=t.priority AND p.type='priority' 208 ORDER BY t.milestone, p.value, t.severity, t.time 209 }}} 210 211 '''Note:''' A table join is used to match ''ticket'' priorities with their 212 numeric representation from the ''enum'' table. 203 t.id AS ticket, summary 204 FROM ticket t,enum p 205 WHERE t.status IN ('new', 'assigned', 'reopened') 206 AND p.name = t.priority AND p.type = 'priority' 207 ORDER BY t.milestone, p.value, t.severity, t.time 208 }}} 209 210 '''Note:''' A table join is used to match ''ticket'' priorities with their numeric representation from the ''enum'' table. 213 211 214 212 === Changing layout of report rows === #column-syntax 215 By default, all columns on each row are display on a single row in the HTML 216 report, possibly formatted according to the descriptions above. However, it's 217 also possible to create multi-line report entries. 213 214 By default, all columns on each row are display on a single row in the HTML report, possibly formatted according to the descriptions above. However, it is also possible to create multi-line report entries. 218 215 219 216 * '''`column_`''' — ''Break row after this''. By appending an underscore ('_') to the column name, the remaining columns will be continued on a second line. … … 226 223 '''Example:''' ''List active tickets, grouped by milestone, colored by priority, with description and multi-line layout'' 227 224 228 {{{ 225 {{{#!sql 229 226 SELECT p.value AS __color__, 230 227 t.milestone AS __group__, … … 237 234 description AS _description_, -- ## Uses a full row 238 235 changetime AS _changetime, reporter AS _reporter -- ## Hidden from HTML output 239 240 241 AND p.name=t.priority AND p.type='priority'242 243 }}} 244 245 === Reporting on custom fields ===236 FROM ticket t,enum p 237 WHERE t.status IN ('new', 'assigned', 'reopened') 238 AND p.name = t.priority AND p.type = 'priority' 239 ORDER BY t.milestone, p.value, t.severity, t.time 240 }}} 241 242 === Reporting on custom fields 246 243 247 244 If you have added custom fields to your tickets (see TracTicketsCustomFields), you can write a SQL query to cover them. You'll need to make a join on the ticket_custom table, but this isn't especially easy. … … 253 250 Beyond the relatively trivial replacement of dynamic variables, the SQL query is also altered in order to support two features of the reports: 254 251 1. [#sort-order changing the sort order] 255 2. pagination support (limitation of the number of result rows displayed on each page)252 1. pagination support (limitation of the number of result rows displayed on each page) 256 253 In order to support the first feature, the sort column is inserted in the `ORDER BY` clause in the first position or in the second position if a `__group__` column is specified (an `ORDER BY` clause is created if needed). In order to support pagination, a `LIMIT ... OFFSET ...` clause is appended. 257 254 The query might be too complex for the automatic rewrite to work correctly, resulting in an erroneous query. In this case you still have the possibility to control exactly how the rewrite is done by manually inserting the following tokens: … … 261 258 262 259 Let's take an example, consider the following SQL query: 263 {{{ 260 {{{#!sql 264 261 -- ## 4: Assigned, Active Tickets by Owner ## -- 265 262 … … 273 270 changetime AS _changetime, description AS _description, 274 271 reporter AS _reporter 275 276 277 AND p.name=t.priority AND p.type='priority'278 272 FROM ticket t,enum p 273 WHERE status = 'assigned' 274 AND p.name = t.priority AND p.type = 'priority' 275 ORDER BY __group__, p.value, severity, time 279 276 }}} 280 277 281 278 The automatic rewrite will be the following (4 rows per page, page 2, sorted by `component`): 282 {{{ 279 {{{#!sql 283 280 SELECT p.value AS __color__, 284 281 owner AS __group__, … … 286 283 changetime AS _changetime, description AS _description, 287 284 reporter AS _reporter 288 289 290 AND p.name=t.priority AND p.type='priority'291 292 285 FROM ticket t,enum p 286 WHERE status = 'assigned' 287 AND p.name = t.priority AND p.type = 'priority' 288 ORDER BY __group__ ASC, `component` ASC, __group__, p.value, severity, time 289 LIMIT 4 OFFSET 4 293 290 }}} 294 291 295 292 The equivalent SQL query with the rewrite tokens would have been: 296 {{{ 293 {{{#!sql 297 294 SELECT p.value AS __color__, 298 295 owner AS __group__, … … 300 297 changetime AS _changetime, description AS _description, 301 298 reporter AS _reporter 302 303 304 AND p.name=t.priority AND p.type='priority'305 299 FROM ticket t,enum p 300 WHERE status = 'assigned' 301 AND p.name = t.priority AND p.type = 'priority' 302 ORDER BY __group__, @SORT_COLUMN@, p.value, severity, time 306 303 @LIMIT_OFFSET@ 307 304 }}} 308 305 309 306 If you want to always sort first by priority and only then by the user selected sort column, simply use the following `ORDER BY` clause: 310 {{{ 311 307 {{{#!sql 308 ORDER BY __group__, p.value, @SORT_COLUMN@, severity, time 312 309 }}} 313 310
