Changes between Version 17 and Version 18 of Release/7.8.0-News
- Aug 18, 2019, 2:30:39 PM (5 years ago)
Release/7.8.0-News
v17 v18 62 62 63 63 Start script: 64 * G78:grass: stop clearing the terminal upon closing; shorten GRASS prompt; do not require dev pkg to be installed for path `grass --config path` as well as `version` and `svn_revision`. Note that revision is currently broken due to Subversion to Git migration. 64 * G78:grass7: stop clearing the terminal upon closing; shorten GRASS prompt; do not require dev pkg to be installed for path `grass --config path` as well as `version` and `svn_revision`. Note that revision is currently broken due to Subversion to Git migration. 65 * G78:grass7: added --config svn_revision 66 * G78:grass7: add powershell shell support 67 * G78:grass7: browser = xdg-open as fallback; no browser message spam in batch jobs 68 * G78:grass7: clean up sqlite DB if existing upon session closing 65 69 66 70 Modules: … … 74 78 * G78:g.proj: list_codes to list codes for given authority, compatible with PROJ 4, 5, 6 75 79 * G78:g.proj: need GRASS_PROJSHARE to list codes with PROJ 4 76 * G78:grass: added --config svn_revision77 * G78:grass: add powershell shell support78 * G78:grass: browser = xdg-open as fallback; no browser message spam in batch jobs79 * G78:grass: clean up sqlite DB if existing upon session closing80 80 * G78:i.atcorr: Worldview4 filter functions added 81 81 * G78:i.gensig: skip NULL cells when calculating variance
