Changes between Version 8 and Version 9 of Release/7.6.0-News
- Oct 14, 2018, 6:30:54 AM (6 years ago)
Release/7.6.0-News
v8 v9 49 49 ==== New modules ==== 50 50 51 * ...51 * G76:r.buildvrt: Build a VRT (Virtual Raster) from the list of input raster maps 52 52 53 53 ==== Major module changes ==== … … 61 61 (see also below for closed bugs) 62 62 63 * G76:r.colors: add inferno, magma and plasma color tables 63 64 * G76:r.colors and G76:r3.colors: new flag -d to list available rules with description (e.g. "srtm: color palette for Shuttle Radar Topography Mission elevation [range: -11000 to 8850]") 65 * G76:r.fillnulls: RST segmax/npmin logic is fixed to avoid segmentation on small holes 66 * G76:r.mapcalc: Do not add extra spaces when inserting a map name or function in GUI 64 67 * G76:r.slope.aspect: add -n option to create aspect as degrees clockwise from North (azimuth), with flat = -9999 65 * G76:r.mapcalc: Do not add extra spaces when inserting a map name or function in GUI 66 * G76:r.fillnulls: RST segmax/npmin logic is fixed to avoid segmentation on small holes 68 * G76:v.colors: add inferno, magma and plasma color tables 67 69 * G76:v.profile: Use GEOS for buffer generation due to errors in native buffering functions 70 68 71 ==== Improvements in the Graphical User Interface ==== 69 72 70 * G76:wxGUI: ... 73 * wxGUI/dbmgr: don't show db info connection by default, it's just occupying space in the dialog 71 74 72 75 ==== Scripting ==== 73 76 74 * pygrass: Atempt to access data from a closed raster map now rises IndexError 77 * pygrass: Attempt to access data from a closed raster map now rises IndexError 78 * Python scripting: add tempname() function to grass.script.core, fix #3615 79 * array.py: added quiet option to write function 80 * db.py: added option in db_table_in_vector to check by default only vectors in current mapset 75 81 76 82 ==== Projection support ==== 77 83 78 * Support of PROJ v.5 84 * Support of PROJ v.5 85 * configure: use new PROJ API only with proj-5.1.x or higher, otherwise fall back to old PROJ.4 API 79 86 80 87 ==== Library changes ==== 81 88 82 * ...89 * ... 83 90 84 91 ==== User Manuals - Documentation ==== … … 88 95 ==== Portability ==== 89 96 90 * ... 97 * config.guess + config.sub updated from http://git.savannah.gnu.org/cgit/config.git/plain/ 98 99 ==== Docker support ==== 100 101 * Dockerfile: dependencies updated, cleanup, added ZSTD, liblas and OpenJPEG/JP2 support 102 * Dockerfile: 'set ENV SHELL' to avoid /bin/sh fallback in interactive GRASS GIS sessions in docker 91 103 92 104 ==== Message Translations ==== 93 105 94 * i18N: ...106 * i18N: ... 95 107 96 108 === New Addons since GRASS 7.6.0 ===
