Changes between Version 31 and Version 32 of Release/7.6.0-News
Jan 20, 2019, 10:28:09 AM (5 years ago)
neteler
21 new addons!
  • Release/7.6.0-News
    v31 v32
    316316 * i18N: added various new languages from Transifex (https://www.transifex.com/grass-gis/grass7/dashboard/)
    317317
    318 === New Addons since GRASS 7.6.0 ===
    319
    320  * G7A:...
    321  * TODO
    322
     318=== New Addons since GRASS 7.4 ===
     319
     320 * G7A:d.vect.colhist - Draws the histogram of values in a vector attribute column
     321 * G7A:i.ann.maskrcnn - The Mask R-CNN tools allow the user to train their own model and use it for a detection of objects, or to use a model provided by someone else. It can be seen as a supervised classification using convolutional neural networks.
     322 * G7A:i.ann.maskrcnn.train - Train your Mask R-CNN network
     323 * G7A:i.cutlines - Creates semantically meaningful tile borders
     324 * G7A:i.pysptools.unmix - Extract endmembers from imagery group and perform spectral unmixing using pysptools
     325 * G7A:i.rh - Water in atmosphere: relative humidity, water vapour (saturated, actual)
     326 * G7A:i.sentinel.mask - Creates clouds and shadows masks for Sentinel-2 images
     327 * G7A:i.signature.copy - Copies signature file from a group/subgroup to another group/subgroup
     328 * G7A:i.signature.list - Lists signature file of a group/subgroup
     329 * G7A:i.signature.remove - Removes signature file in a group/subgroup
     330 * G7A:r.accumulate - Calculates weighted flow accumulation, stream networks, and the longest flow path using a flow direction map
     331 * G7A:r.category.trim - Exports categories and corresponding colors as QGIS colour file or csv file. Non-existing categories and their colour definitions will be removed
     332 * renamed r.sentinel -> G7A:i.sentinel
     333 * G7A:r.estimap.recreation - Implementation of ESTIMAP to support mapping and modelling of ecosystem services (Zulian, 2014)
     334 * G7A:r.in.pdal - Creates a raster map from LAS LiDAR points using univariate statistics and r.in.xyz
     335 * G7A:r.lfp - Calculates the longest flow paths for given outlet points using the r.stream.distance addon.
     336 * renamed r.modis -> G7A:i.modis
     337 * G7A:r.wateroutlet.lessmem - Creates watershed basins from a drainage direction map. It is a modified version of r.water.outlet and requires about one third of memory compared to the original module
     338 * G7A:t.rast.null - Manages NULL-values of a given space time raster dataset
     339 * G7A:v.clean.ogr - Imports vector data into a GRASS vector map, cleans the data topologically, and exports them again using OGR library
     340 * G7A:v.gsflow.mapdata - Upload data to PRMS data (GSFLOW)
     341 * G7A:v.rast.bufferstats - Calculates statistics of raster map(s) for buffers around vector geometries
     342 * G7A:v.what.strds.timestamp - Uploads space time raster dataset values to the attribute table at positions of vector points in space and time
    323343=== Closed tickets ===
    324344
