Changes between Version 5 and Version 6 of Release/7.2.1-News
- Apr 9, 2017, 4:04:12 AM (7 years ago)
Release/7.2.1-News
v5 v6 42 42 ==== New modules ==== 43 43 44 * ...44 * None 45 45 46 46 ==== Major module changes ==== 47 47 48 * ...48 * None 49 49 50 50 ==== Minor module changes ==== … … 53 53 * G72:r.timestamp: typo in the manual 54 54 * G72:r.to.vect: Call the DB error handler before the vector handler to avoid busy database warnings 55 * G72:r.topmodel: Fix cumulative infiltration 55 56 * G72:v.build.polylines: Activate the cats=same option; Remove compile warnings 56 57 * G72:v.db.addtable: Check for duplicate column names … … 62 63 * G72:v.to.points: Don't interpolate for use=node according to the manual 63 64 * G72:v.what: Fix the default distance threshold 65 * G72:v.overlay: fix test if line is inside an area (#3319) 66 * G72:r.what: fix segfault when using -r and outside of region 67 * G72:i.zc: correctly read the threshold value, set to 1 by default and divided by 100 internally 68 * G72:v.out.postgis: fix type option (closes #2460) 69 * G72:v.out.ogr: Append mode broken in G 7.2.1svn and 7.3 70 * G72:i.modis.qc manual: added note on MOD11A2 QC_band NULLs treatment 71 * G72:v.what.rast: segfault with map without topology 72 * G72:v.external.out: SRID lost when not exactly defined 73 * G72:v.external: fix dsn handling (full / db-login-based connection strings) 74 * G72:r.resamp.stats: Introduce also other stats methods to resampling module to better match r.neigbors offer 75 * G72:v.proj: add no topology flag 76 * G72:v.external: fix check_projection() when input is PG datasource (and native GRASS PostGIS reader is used) 77 * G72:i.atcorr: Pleiades-1A, Pleiades-1B, Spot-6, Spot-7, Worldview-3 support added 78 * G72:v.out.postgis doesn't export attribute table (see #2460) 64 79 65 80 ==== GUI changes ==== 66 81 67 * ... 82 * wxGUI: 'Align computation region to selected map' add to the layer menu 83 * wxGUI: do not re-render whole map composition when show/hide comp. region extent 84 * wxGUI/location wizard simplification: decrease number of dialogs shown by default 68 85 69 86 ==== PyGRASS changes ==== 70 87 71 * ... 88 * use lazy imports for the temporal package 89 * Python 2.6 does not support ommitting of positional argument specifiers: Fixes ValueError zero length field name in format 72 90 73 91 ==== Library changes ==== 74 92 75 * ... 93 * vectorlib: enhance numerical stability for segment intersections 94 * vectorlib, network analysis: initialize output, fix shortcut, prune path 95 * OGR dbdriver: support OFTInteger64 76 96 77 97 ==== Map projection changes ==== 78 98 79 * ...99 * None 80 100 81 101 ==== Portability changes ==== 82 102 83 * ...103 * None 84 104 85 105 ===== MS Windows ===== 86 106 87 * ...107 * grass.py: Force encoding to be EUC-KR for the Korean language in Windows 88 108 89 109 ==== Manual pages ==== 90 110 91 * ... 111 * G72:v.to.rast: fix description of option use=dir to not limit it to flow, add better example with picture to manual 112 * r.import/v.import manual: explain -o projection override flag 113 * rasterintro manual: explain optional NULL compression 114 * doc: include all modules into graphical index 115 * broken links to source code and history in add-ons user manuals (see #3224) 92 116 93 117 ==== Message translation updates ==== 94 118 95 * ... 119 * Czech translation (libs): add missing plural forms 120 * i18N: Sylvain Maillard French cont'ed 96 121 97 122 === New Addons === … … 99 124 New addons since release 7.2.1: 100 125 101 * ...126 * TODO 102 127 103 128 === Closed tickets ===
