Changes between Version 4 and Version 5 of Release/7.0.4-News
Apr 18, 2016, 2:21:10 PM (8 years ago)
neteler
GRASS GIS 7.0.4RC1
  • Release/7.0.4-News
    v4 v5
    1111==== Release Candidate 1 (RC1) ====
    1212
    13  * ~~Release date: ''DD MM 2016''
     13 * Release date: ''18 Apr 2016''
    1414 * ~~Announcement: https://grass.osgeo.org/news/51/117/GRASS-GIS-7-0-4RC1-released/~~
    15  * ~~Changelog: http://grass.osgeo.org/grass70/source/ChangeLog_7.0.4RC1.gz~~
    16  * ~~Binaries: ​http://grass.osgeo.org/download/software/#g70x~~
    17  * ~~Source code: http://grass.osgeo.org/grass70/source/grass-7.0.4RC1.tar.gz ([http://grass.osgeo.org/grass70/source/grass-7.0.4RC1.md5sum md5sum])~~
    18  * ~~SVN Source Code Checkout 7.0.4RC1:~~
     15 * Changelog: http://grass.osgeo.org/grass70/source/ChangeLog_7.0.4RC1.gz
     16 * Binaries: ​http://grass.osgeo.org/download/software/#g70x
     17 * Source code: http://grass.osgeo.org/grass70/source/grass-7.0.4RC1.tar.gz ([http://grass.osgeo.org/grass70/source/grass-7.0.4RC1.md5sum md5sum])
     18 * SVN Source Code Checkout 7.0.4RC1:
    1919{{{
    20   svn checkout http://svn.osgeo.org/grass/grass/tags/release_2016XXXX_grass_7_0_4RC1
     20  svn checkout http://svn.osgeo.org/grass/grass/tags/release_20160418_grass_7_0_4RC1
    2121}}}
    2223
    2324=== SVN Source Code ===
    3334A series of stability fixes, manual improvements and a few language translations have been added.
    3435
    35 The GRASS GIS 7.0.4 release provides '''more than XXX fixes and improvements''' with respect to GRASS GIS 7.0.3.
     36The GRASS GIS 7.0.4RC1 release provides '''more than 140 fixes and improvements''' with respect to GRASS GIS 7.0.3.
    3637
    3738==== New modules ====
    4142==== Major module changes ====
    4243
    43  * ...
     44 * G7:db.login + PG & mySQL driver: support hostname and port
     45 * G7:g.proj: read EPSG CSV files from GDAL data directory and no longer an private and meanwhile outdated copy (solves #2456)
     46 * G7:r.in.lidar: fix scan box calculation for percent < 100
     47 * G7:r.in.xyz: fix scan box calculation for percent < 100
     48 * G7:r.mapcalc: Fix row cache bug
     49 * G7:r.series: sync weights handling to r.neighbors
     50 * G7:r.sun: mode 1 fix for time offset due to timezone, see #2941 for explanations
     51 * G7:v.in.ogr: declare missing values in string and date fields as NULL, not empty strings
     52 * G7:v.select: fix reverse selection of areas
     53 * G7:v.net.steiner: shortest road is searched between node not line id's
    4454
    4555==== Minor module changes ====
    4656
    47  * ...
     57 * G7:g.extension: option to specify proxy server #1434
     58 * G7:r.external: added -t flag for listing bands
     59 * G7:r.transect: use new r.profile parameter names
     60 * G7:v.db.join: fix cache exception
     61 * G7:v.distance: use bbox in 2D and 3D accordingly
     62 * G7:v.net.distance: change path categories, adjust line directions; add new flag to produce single line paths
     63 * G7:v.to.db: allow (unitless) calculation of perimeter in XY location
    4864
    4965==== GUI changes ====
    5066
     67 * G7:g.gui.mapswipe: fix raster layout (wxPython3)
     68 * G7:g.gui.gmodeler - all layers rewritten by last output for more than one parameter; add support for dbtables; many further fixes
     69 * Install additional hicolor icon sizes
    5170 * listing maps in map selection widget using natural sort (#2818)
     71 * wxGUI: fix histogram of imagery group on Windows, see #2961
     72 * wxGUI: apply natural sort also when filtering data
    5273
    5374==== Library changes ====
    5475
    55  * ...
     76 * libraster: support linking GDAL2
     77 * libraster: check for compressed null file
     78 * vlib: add 2D version of point in box function
     79 * vlib: support different graph versions
    5680
    5781==== PyGRASS changes ====
    5882
    59  * ...
     83 * pygrass: fixed grid doctest
    6084
    6185==== Map projection changes ====
    6286
    63  * n/a
     87 * libgis: datum added related to SIRGAS 2000/EPSG:4674
     88 * libproj: read EPSG CSV files from GDAL data directory and no longer an private and meanwhile outdated copy (solves #2456)
     89 * libproj: fix mixing of projection name and coordinate system name
    6490
    6591==== Portability changes ====
    6692
    67  * ...
     93 * Mac OSX: fix compilation of certain addons, lowercase r flag does not work on Mac
    6894
    6995===== MS Windows =====
    7096
    71  * ...
     97 * wingrass: document GRASS_SH (how to switch from cmd to bash, see r68212)
     98 * wingrass: build against GDAL 2
    7299
    73100==== Manual pages ====
    74101
    75  * ...
     102 * manual: avoid specific gender
     103 * G7:g.findfile manual: shell examples extended
     104 * G7:g.gui.gmodeler: major manual improvements
     105 * G7:r.li manual: highlight GUI and configuration file
     106 * G7:r.pack manual: explain current region behaviour
     107 * G7:v.buffer manual: demystify caps
     108 * G7:v.net.spanningtree: update manual
     109 * G7:v.proj manual: describe automated vertex densification
     110 * G7:v.split manual: examples updated
     111 * G7:v.to.points manual: new NC sample data example
     112 * G7:t.register manual: ECAD example added
     113 * G7:t.vect.observe.strds manual: demystify 'where' clause usage
     114 * wxGUI/dbmgr: update images in the manual
     115
    76116
    77117==== Message translation updates ====
    78118
    79  * ...
     119 * Spanish translation
    80120
    81121=== Closed tickets ===
