Changes between Version 25 and Version 26 of Release/6.4.0RC1-News
Dec 23, 2008, 6:34:06 AM (15 years ago)
neteler
+Closed tickets
  • Release/6.4.0RC1-News
    v25 v26
    11= ~~GRASS GIS 6.4.0RC1 Release~~ =
     3[[TOC]]
    35'''''~ NOT YET RELEASED: this page is a work in progress ~'''''
    5254 * New grass.py Python library giving standardized access to GRASS modules
    5355
     56==== Closed tickets ====
     57 * "Additional tools" menu dialog broken in digitizer (trac #208)
     58 * "Set options" for scale and N arrow fails (trac #288)
     59 * "Stop" button should not be active until the module starts running (trac #219)
     60 * 'Move line' and 'Delete line' when digitizing (trac #25)
     61 * *.tcl installed as executable (trac #388)
     62 * ./configure: cosmetics (trac #44)
     63 * Ability to handle subgroups with general commands as all other datatypes (trac #324)
     64 * Add "Help" button as in gis.m (trac #221)
     65 * Add created map into layer tree: errors for import modules (trac #305)
     66 * Compiler error while building python swig (trac #308)
     67 * Compiling QGIS from svn has a compiler error related to GRASS api (trac #364)
     68 * Convert tcl grc to wxpython version (trac #80)
     69 * Could not set snapping threshold (trac #92)
     70 * Enhancement to r.cross - add more layers to cross (trac #330)
     71 * Erase display crashes (trac #292)
     72 * Error in in defining new location via EPSG code in wxpython Location Wizard (trac #191)
     73 * Error with r.drain with gdal 1.5.2 and 1.6.0 (trac #351)
     74 * Extend GRASS-command history (at least to 1000) by default (trac #132)
     75 * GRASS will bould nviz eaven without tcl/tk (trac #164)
     76 * Grass63 -wx gui function r.in.xyz form not consistent with other wx gui forms. (trac #16)
     77 * Grass63 -wx gui function r.in.xyz form not updating input fields. (trac #18)
     78 * Grass63 -wx gui function v.in.ogr form not consistent with other wx gui forms. (trac #17)
     79 * Grass63 -wx gui menu item referes to incorrect function (trac #15)
     80 * Location wizard: browse button half-cut (trac #216)
     81 * Location wizard: scroll issue in EPSG code selection (trac #4)
     82 * Location wizard: show sample map in region settings dialog (trac #8)
     83 * Location wizard: sort list from EPSG browser (trac #5)
     84 * MySQL driver: create table command cut (trac #188)
     85 * NVIZ displays points (sites) allways as thematic (trac #49)
     86 * NVIZ. Shrinking of the surface when the surface resolution is increased (GRASS6.2.3-GRASS6.3) (trac #56)
     87 * NVIZ: pack menu to the left (trac #348)
     88 * New v.example proposal (trac #120)
     89 * Query vector map (edit mode): does not work (trac #277)
     90 * SQL builder prints the name of the vector map to the terminal (trac #206)
     91 * Setting to have the computational region extent, like the one on the display (trac #183)
     92 * Sqlite driver doesn't handle blank numeric entries (trac #180)
     93 * Suggestion for the new (wx) grass-gui "File" menu (trac #393)
     94 * Support for multiple 'percentile' arguments in r.univar (trac #19)
     95 * TODO: move high priority incubated modules into main (trac #344)
     96 * Tcl version of v.digit's background colour doesn't work (trac #74)
     97 * Typo in "i.oif.html" and wording (trac #329)
     98 * Unable to create file [REF] for subgroup (trac #133)
     99 * Unable to create file [REF] for subgroup [sub-test] of group [test in neuba] (trac #174)
     100 * Update config.guess in SVN (trac #158)
     101 * Using barin option in r.flow produce segmentation fault (trac #403)
     102 * !ValueError: unsupported format character '<' (0x3c) at index 4 (trac #366)
     103 * Vlib patch that provides Vect_line_get_intersections function (trac #357)
     104 * WinGRASS Tcl/Tk GUI - Text formatting error in Output window (trac #127)
     105 * WinGRASS: i.ortho.photo fails (trac #168)
     106 * WinGRASS: v.report incompatability issue (trac #160)
     107 * Wxgrass: Set computational region to the minimum necessary to enclose map data extent (trac #157)
     108 * Zoom in / Zoom out enhancement (trac #24)
     109 * add a minimum distance threshold to v.distance (trac #253)
     110 * adding other layer than plain raster or vector (shaded relief, thematic vector etc.) returns an error (trac #258)
     111 * can't edit a vector map if the name has no @mapset suffix (trac #236)
     112 * can't overwrite vector map if it's name is fully qualified (i.e. contains @mapset) (trac #246)
     113 * computational region extent frame should be semi-transparent (trac #294)
     114 * config.in: cairo and ffmpeg checks (trac #33)
     115 * configure.in: wxwidgets and python checks (trac #38)
     116 * copy command syntax does not work (trac #245)
     117 * d.labels doesn't place labels exactly on coordinate point in label file. (trac #340)
     118 * d.legend: apply arbitrary labels to a smooth floating-point colorbar (trac #124)
     119 * d.mon doesn't work (Wingrass commandline) (trac #339)
     120 * d.vect / v.univar does not work for layer > 1 ; v.db.join has bugs (corrected here) (trac #338)
     121 * d.vect: disp=cat or attr draws area shapes (trac #71)
     122 * d.vect: flag to print mininal region extent (trac #262)
     123 * db.table -p does not list all tables -> deeper problems in PostgreSQL driver (trac #93)
     124 * db/drivers/dbf fail to build due to undefined reference to 'SASetupDefaultHooks' (SHAPELIB) (trac #110)
     125 * description for v.db.reconnect.all (trac #385)
     126 * develbranch6 r33422 fails to configure on regex (trac #310)
     127 * digitizer: don't ask to save changes when there have been none (trac #210)
     128 * digitizer: errors at copying categories (trac #213)
     129 * digitizer: errors at editing line (trac #214)
     130 * digitizer: errors at querying (trac #212)
     131 * digitizer: errors at removing vertex (trac #211)
     132 * division with dbf driver leads to protocol error (trac #185)
     133 * error at wxGUI startup (trac #238)
     134 * error in table manager (trac #285)
     135 * error printed to the terminal after executing command from wxGUI cmd line (trac #228)
     136 * error querying a layer being edited (trac #264)
     137 * error when adding another text layer (trac #301)
     138 * error when digitizing new feature (trac #30)
     139 * g.copy segfaults (debian.gfoss.it package) [and latest SVN] (trac #50)
     140 * g.findfile element=colr2 (trac #326)
     141 * g.mapsets crash (trac #41)
     142 * g.mkfontcap: extradirs=path seems to fail (trac #368)
     143 * g.parser buffer overflow terminates shell script (trac #356)
     144 * g.parser terminated when execute scripts just like g.manual, v.report etc. (trac #347)
     145 * g.region segmentation violation when creating EPSG:4326 location (trac #367)
     146 * g.region should not duplicate the code of G3d_regionToCellHead () (trac #122)
     147 * g.region should set (top, bottom) from the 3d vector specified by vect= (trac #121)
     148 * georectifier: add options to invoke/not invoke -c flag for i.rectify (trac #249)
     149 * gis.m: Raster Legend text selection button gives error (trac #79)
     150 * grass build fails when build with -as-needed linker flag (trac #69)
     151 * grass-6.2.3 and flex-2.5.34, missing the description.html (trac #2)
     152 * i.fusion.brovey: remove temp region file? (trac #194)
     153 * init.sh: cleanup session $tmp on exit and require -c to create mapset from the command line (trac #53)
     154 * let visualize line directions in digitizer (trac #209)
     155 * moving of vector object by mouse (trac #29)
     156 * multiple tools should not be selectable (trac #265)
     157 * new module g.gui (trac #43)
     158 * new tabs in GUI have required last (trac #102)
     159 * once enabled, autorendering mode can't be disabled in the current session (trac #269)
     160 * precompiled Cygwin Windows grass 6.3.0 does not have sqlite driver support (trac #316)
     161 * ps.map documentation lists incorrect values for vlines "type" option (trac #34)
     162 * ps.map generates invalid postscript when vlegend item does not appear on map (trac #355)
     163 * ps.map manual - spearfish example (trac #362)
     164 * ps.map: patch to set customized scalebar units (trac #64)
     165 * ps.map: the "M" highlight problem (trac #155)
     166 * query tool crashes when the user presses mouse buttons fast (trac #281)
     167 * r.colors -e flag does not use full color range if map values are between 0. and 1. (trac #336)
     168 * r.digit: make guarantee_xmon fail nicely on WinGrass (trac #117)
     169 * r.grow.distance, r.random.surface ignores raster MASK (trac #387)
     170 * r.in.xyz: zscale parameter addition patch (trac #105)
     171 * r.li.index in 6.3.1 svn doesn't work (trac #231)
     172 * r.los broken on Mac (trac #101)
     173 * r.los: patch to support earth curvature (trac #63)
     174 * r.mask -r shouldn't require input (trac #223)
     175 * r.patch fails on Vista (trac #118)
     176 * r.random fails with bus error on Mac OS X 10.5 (trac #97)
     177 * r.regressionline incompatability issue in WinGRASS (trac #162)
     178 * r.sim.*: use G_command_history() (trac #48)
     179 * r.statistics: output should be optional (trac #116)
     180 * r.watershed: speed improvement (trac #237)
     181 * r.what in wxGUI should not depend on computational region (trac #282)
     182 * r.what.colors: not working (trac #152)
     183 * region corrupted (trac #295)
     184 * saving display to tiff or ppm garbled when NVIZ is not top window (trac #104)
     185 * sfd support for r.terraflow (trac #197)
     186 * short integer overflow with r.in.gdal (trac #166)
     187 * some commands dialogs have their name crippled (trac #272)
     188 * table manager tools print plenty of warnings to the terminal (trac #207)
     189 * table manager: edits in the table are not saved (trac #235)
     190 * text layer overlay: font and rotation don't work (trac #302)
     191 * the "command layer" in wxGUI does not work (trac #268)
     192 * update demolocation/ for GRASS 6 (trac #144)
     193 * use a different default for wxGUI displays (trac #290)
     194 * v.db.join fails in winNative Grass 6.3 for sqlite driver (trac #315)
     195 * v.generalize Assertion failed. (trac #36)
     196 * v.generalize: which options apply to which methods? (trac #374)
     197 * v.in.ascii has no progress bar in any GUI (same as v.proj) (trac #244)
     198 * v.in.ascii wxpython gui crashes when importing xyz files. (trac #186)
     199 * v.in.garmin - detect gpstrans or gardump instead of user flag (trac #184)
     200 * v.in.geonames fails on Polish dataset (trac #202)
     201 * v.in.geonames wxGUI window crashes or freezes when "Verbose module output" is checked (trac #201)
     202 * v.label.editor (trac #409)
     203 * v.mkgrid - segmentation fault (trac #361)
     204 * v.out.gpsbabel (trac #349)
     205 * v.out.ogr does not correctly encode NODATA in attribute tables (trac #333)
     206 * v.out.ogr does not export features when 'dsn' AND 'layer' options are given (trac #327)
     207 * v.out.ogr exports only attribute data in CSV format (trac #28)
     208 * v.out.ogr: bad DB read for format=GPX (trac #354)
     209 * v.proj has no progress bar in any GUI (trac #243)
     210 * v.proj: broken (?) -z description and missing -l description in wxGUI (trac #241)
     211 * v.random: add random sampling from vector points map (trac #229)
     212 * v.select: segfault in dig_alloc_points (trac #380)
     213 * v.to.db example incorrectly uses "type=area" (trac #360)
     214 * v.to.db: type description corrupted in wxGUI (trac #233)
     215 * v.to.rast segfaults in G_close_gdal_link() (trac #319)
     216 * v.what returns "Line:" attribute for points and centroids (trac #267)
     217 * various error messges during digitizing (trac #227)
     218 * vdigit crashes on some GRASS vectors I try to edit (trac #225)
     219 * vdigit is missing a tool to delete categories (trac #266)
     220 * vdigit: an improvement for "Copy features from (background) map" (trac #284)
     221 * vdigit: cursor and vertex are apart when moving vertices (trac #274)
     222 * vdigit: please render closed areas transparent (trac #276)
     223 * warnings printed on GRASS startup when selecting Location and Mapset (trac #204)
     224 * wrong translations break wxGUI (trac #296)
     225 * wxGUI doesn't handle removing maps (trac #280)
     226 * wxGUI fails to handle illegal region extent (trac #299)
     227 * wxGUI modules don't refresh the list of available maps (trac #218)
     228 * wxGUI should provide a switch for region-constrained/free display mode (trac #293)
     229 * wxGUI: "Color rules" prints an error when "Preview" is pressed (trac #279)
     230 * wxGUI: can't handle whole-Earth extent (trac #395)
     231 * wxGUI: can't really cancel adding layer (trac #257)
     232 * wxGUI: can't render layer different than 1 (trac #371)
     233 * wxGUI: db.droptable button opens db.login (trac #255)
     234 * wxGUI: sqlbuilder.py patch for columns listing (trac #261)
     235 * wxGUI: visualization problems with multiple rasters and vectors. not stable bug... (trac #259)
     236 * wxNVIZ fails to start (trac #275)
     237 * wxNVIZ: crash or failure (trac #297)
     238 * wxNviz does not start (trac #404)
     239 * wxPython GUI fails in Windows Vista if GISDBASE contains spaces (trac #114)
     240 * wxgrass - d.vect and d.vect.chart: changing default checkbox options in GUI results in KeyError (trac #109)
     241 * wxgrass gui help is missing from 6.4.svn (trac #146)
     242 * wxgrass: Allow disabling of remove layer promp in GIS Layer Manager (trac #139)
     243 * wxgrass: Error in applying display overlay properties to rasters in Layer Manager (trac #145)
     244 * wxgrass: Error in profile tool (trac #137)
     245 * wxgrass: Remember the position of gui windows on Grass exit (trac #130)
     246 * wxgrass: Some statusbar modes obscure mouse-over help text of gui tools (trac #135)
     247 * wxgrass: delete point map geometry when deleting attribute (trac #314)
     248 * wxgrass: should automatically open display if layer added with no open display (trac #113)
     249 * wxgrass: show module name in bottom line of main window (trac #10)
     250 * wxgrass: ticking -m options in legend dialog cause general GUI freeze (trac #119)
     251 * wxgrass: trying to add legend gives UnicodeDecodeError (trac #108)
     252 * wxgrass: trying to set options for scalebar or legend gives TypeError (trac #107)
     253 * wxgrass: zoom to computational region does not respect resolution set with g.region (trac #106)
     254 * wxgui: Show attribute data depends on global db connection, not file db connection parameter (trac #381)
     255 * wxgui: v.in.ascii's SQL column defintion text box is uneditable (trac #263)
     256 * wxpython Layer Manager: higher raster hides the lower (trac #254)
     257 * wxpython gui crashed while importing dxf (trac #176)
     258 * wxpython gui for v.in.dxf defaults to overwrite (trac #177)
     259 * wxpython: Layer Manager crashes when trying to edit vector properties (trac #159)
     260
     261
    54262=== SVN Source Code ===
    55263
