Changes between Version 362 and Version 363 of Grass7Planning
- Sep 16, 2017, 6:31:26 AM (7 years ago)
Grass7Planning
v362 v363 39 39 * vector modules: Added layer specific database information to v.info extended metadata flag: r69535 40 40 * i18N: Install gettext to Python script modules to use translated strings extracted by r70817: r70818 41 * ~v.what.strds: add capabilities to use names also for temporal dataset with minutes and seconds granularity: r69331~42 * ~~v.in.lidar: r70134~~ (done)43 * ~~d.linegraph: a series of improvements, see https://trac.osgeo.org/grass/log/grass/trunk/display/d.linegraph/main.c~~ (wenzeslaus: most are improvements/features, a lot of code changed, leaving it for 7.4)44 * ~~i.atcorr: Sentinel-2A r70161 (Test feedback in ML needed first)~~45 41 * r.grow.distance: clean up after r68611: r69327 46 * ~~r.in.lidar: Storage type~~ (wenzeslaus: not sure what it is, but code is not identical in 7.2 and trunk)47 * ~~r.in.xyz: unify keywords and method descriptions with r.in.lidar (r68596): r68600~~ (done in r71300 and r70291)48 42 * lib/python/temporal: major differences to be checked TODO 49 43 * r.in.srtm: Print an error instead of failing in a XY location: r70819 50 44 45 postponed: 46 * ~~d.linegraph: a series of improvements, see https://trac.osgeo.org/grass/log/grass/trunk/display/d.linegraph/main.c~~ (wenzeslaus: most are improvements/features, a lot of code changed, leaving it for 7.4) 47 * ~~i.atcorr: Sentinel-2A r70161 (Test feedback in ML needed first, leaving it for 7.4)~~ 48 * ~~r.in.lidar: Storage type~~ (wenzeslaus: not sure what it is, but code is not identical in 7.2 and trunk, leaving it for 7.4) 49 * ~~v.what.strds: add capabilities to use names also for temporal dataset with minutes and seconds granularity: r69331 (leaving it for 7.4)~~ 51 50 == Blockers == 52 51
