Changes between Version 261 and Version 262 of Grass7Planning
- Apr 12, 2016, 1:13:41 PM (8 years ago)
Grass7Planning
v261 v262 44 44 === 7.0.4 (to be backported) === 45 45 46 * fix r.sun: patch in #2876 and/or #2941: wrong sign in equation of time 46 * fix mySQL support: [https://trac.osgeo.org/grass/query?status=!closed&keywords=~mysql 2 tickets] 47 * graphic identity - https://lists.osgeo.org/pipermail/grass-dev/2016-January/078528.html 47 48 * ~~r66379: vector/v.random/main.c~~ 48 * This is a feature (increasing limit of generated points), no backport.49 * This is a feature (increasing limit of generated points), no backport. 49 50 * ~~r66460: vector/v.distance/distance.c (see #2734)~~ backported in r68143 and r68146. 50 * fix mySQL support: [https://trac.osgeo.org/grass/query?status=!closed&keywords=~mysql 2 tickets]51 51 * ~~import changes: r67285, r67628, r67631, r67633~~ 52 * martinl: I suggest to avoid this backport, this part of wxGUI code base changed a lot, there is large number of conflicts53 * graphic identity - https://lists.osgeo.org/pipermail/grass-dev/2016-January/078528.html 52 * martinl: I suggest to avoid this backport, this part of wxGUI code base changed a lot, there is large number of conflicts 53 54 54 == Blockers == 55 55
