Changes between Version 40 and Version 41 of Grass7/VectorLib/OGRInterface
Oct 25, 2011, 11:17:20 AM (13 years ago)
martinl
  • Grass7/VectorLib/OGRInterface
    v40 v41
    2121List of modules which supports direct OGR read access ((*) indicates work in progress):
    2222
    23  * {{{v.info}}} (r39161), {{{v.db.connect}}} (r39538), {{{v.extract}}} (r39621), {{{v.db.select}}} (r39556), {{{v.buffer}}} (r39809), {{{v.category}}} (r39812), {{{v.class}}} (r39813), {{{v.clean}}} (r39814), {{{v.delaunay}}} (r39821), {{{v.dissolve}}} (r39822), {{{v.distance}}} (r39823), {{{v.drape}}} (r39826), {{{v.extrude}}} (r39827), {{{v.generalize}}} (r39828), {{{v.hull}}} (r39829), {{{v.kcv}}} (r39832), {{{v.neighbors}}} (r39834), {{{v.normal}}} (r39839), {{{v.out.ascii}}} (r39881), {{{v.out.dxf}}} (r39882), {{{v.out.ogr}}} (r39883), {{{v.out.pov}}} (r39884), {{{v.out.svg}}} (r39885), {{{v.overlay}}} (r39895), {{{v.parallel}}} (r39896), {{{v.pertrub}}} (r39897), {{{v.qcount}}} (r39898), {{{v.report}}} (r39905), {{{v.sample}}} (r39906), {{{v.segment}}} (r39907), {{{v.reclass}}} (r39908), {{{v.random}}} (r39909), {{{v.rast.stats}}} (r39910), {{{v.select}}}, {{{v.split}}}, {{{v.surf.idw}}}, {{{v.surf.rst}}}, {{{v.to.3d}}}, {{{v.to.db}}}, {{{v.to.points}}}, {{{v.to.rast}}}, {{{v.to.rast3}}}, {{{v.transform}}}, {{{v.type}}}, {{{v.univar}}}, {{{v.what}}} (r40188)
     23 * {{{v.info}}} (r39161), {{{v.db.connect}}} (r39538), {{{v.extract}}} (r39621), {{{v.db.select}}} (r39556), {{{v.buffer}}} (r39809), {{{v.category}}} (r39812), {{{v.class}}} (r39813), {{{v.clean}}} (r39814), {{{v.delaunay}}} (r39821), {{{v.dissolve}}} (r39822), {{{v.distance}}} (r39823), {{{v.drape}}} (r39826), {{{v.extrude}}} (r39827), {{{v.generalize}}} (r39828), {{{v.hull}}} (r39829), {{{v.kcv}}} (r39832), {{{v.neighbors}}} (r39834), {{{v.normal}}} (r39839), {{{v.out.ascii}}} (r39881), {{{v.out.dxf}}} (r39882), {{{v.out.ogr}}} (r39883), {{{v.out.pov}}} (r39884), {{{v.out.svg}}} (r39885), {{{v.overlay}}} (r39895), {{{v.parallel}}} (r39896), {{{v.pertrub}}} (r39897), {{{v.qcount}}} (r39898), {{{v.report}}} (r39905), {{{v.sample}}} (r39906), {{{v.segment}}} (r39907), {{{v.reclass}}} (r39908), {{{v.random}}} (r39909), {{{v.rast.stats}}} (r39910), {{{v.split}}}, {{{v.surf.idw}}}, {{{v.surf.rst}}}, {{{v.to.3d}}}, {{{v.to.db}}}, {{{v.to.points}}}, {{{v.to.rast}}}, {{{v.to.rast3}}}, {{{v.transform}}}, {{{v.type}}}, {{{v.univar}}}, {{{v.what}}} (r40188), {{{v.select}}} (48936)
    2424
    2525== Direct OGR write access ==
