Changes between Initial Version and Version 1 of Grass7/TemporalExtension
Jun 29, 2011, 9:51:53 PM (13 years ago)
huhabla
  • Grass7/TemporalExtension
     1= Adding the time dimension to GRASS GIS raster, vector and voxel data types for field based applications using a time stamp approach =
     3== Time stamps in SQL tables ==
     5Raster, vector and voxel maps in GRASS GIS will have temporal attributes by default:
     6  * Creation time
     7  * Modification time
     8  * An absolute or relative time stamp
     9    * absolute:
     10      * start date
     11      * end date
     12    * relative
     13      * a relative time stamp
     14
     15To store the time stamps and to enable temporal queries a SQL DBMS, capable of temporal datatypes, will be used. As default a Sqlite3 database will be used to store map specific informations in database files. Additionally Postgresql should be supported too.
     16
     17In case of SQlite a GRASS SQL database file is created for each mapset in a location. Views are used to access the raster, vector or raster3d map entries of different mapset databases at once.
     18
     19The time stamps as well as attributes and map specific meta data of all created maps in GRASS GIS will be stored in SQL tables in the GRASS SQL databases. The entries in the SQL tables will be created or updated automatically while creation, modification or removement of maps. For each GRASS datatype (raster, raster3d and vector) four SQL tables will be added to GRASS SQL databases at mapset creation:
     20
     21  * The '''base table''' has an equal layout for raster, vector and raster3d maps. This table stores:
     22    * The '''id''' which is of type string. As '''id''' the raster, raster3d or vector map names should be used, because these must be unique in a mapset and can be used as primary  key
     23    * The '''temporal type''' specifies if the time stamp is relative or absolute
     24    * The '''creation date''' is of type datetime
     25    * The '''modification date''' is of type datetime
     27  * The '''absolute time table''' to store the absolute time stamps for each map. The layout is equal for raster, raster3d and vector maps. This table stores:
     28    * The '''id''' as primary key
     29    * The '''start time stamp''' is of type datetime
     30    * The '''end time stamp'''is of type datetime
     31    * The '''time zone'''is of type integer
     32
     33  * The '''relative time table''' to store the relative time stamps for each map. The layout is equal for raster, raster3d and vector maps. This table stores:
     34    * The '''id''' as primary key
     35    * The '''relative time stamp''' is of type datetime
     36
     37A map can only have an absolute or relative time stamp.
     38
     39  * The '''metadata table''' is specific for each grass data type. It stores the spatial and temporal extent as well as map specific attributes (creator, range, cell type, features, registered spacetime datasets, ...)
     40
     41In long term these kind of SQL tables may replace the text file based storage of map metadata, database links and time stamps.
     42
     43== New temporal GRASS datatypes ==
     44
     45To manage temporal raster, raster3d and vector objects, three new datatypes will be added to GRASS GIS: Spacetime raster, vector and voxel datasets. Additionally thematic spatio-temporal datasets will be added to handle thematic related spacetime datasets of different type.
     46
     47Maps can be registered and unregistered in spacetime datasets. Maps are registered by id (name). All available spatio-temporal data is availabe in SQL tables. Cross referencing must be implemented (maps storing the spacetime datasets in which they are registered and vis versa)
     48Spacetime datasets have absolute or relative time type, these types cant be mixed up but converted.
     49
     50A temporal resolution can be set for each spacetime dataset (1s - decades) defining the granularity of the datasets (like the resolution settings for raster/voxel maps).
     51
     52The new spacetime datasets are handled like raster or vector maps. They are registered in mapset specific tables with creation and modification date and absolute/relative time stamp.
     53
     54=== Raster spacetime datasets ===
     56The raster spacetime datasets store raster map specific attributes and metadata:
     57  * The spatial extent (e, w, n, s)
     58  * The temporal extent (start and end time or duration)
     59  * The data range (min and max)
     60  * The raster datatype (CELL, FCELL, DCELL, MIXED)
     61
     62All these table entries are computed or updated via trigger from all registered raster maps when maps are added or removed.
     63
     64Table layout:
     65
     66The base spacetime tables are equal to the raster/vector and raster3d one.
     67
     68  * '''Spacetime metadata raster table'''
     69    * '''id''' the name of the spacetime raster table
     70    * '''temporal type''' relative or absolute
     71    * '''Raster register table name''' the name of the table storing the ids (names) of all registered raster maps
     72    * '''spatial extent''' (4 columns: e, w, s,n) of all registered raster maps
     73    * '''temporal exten'''t of all registered raster maps
     74    * '''data range''' of all registered raster maps
     75    * ...
     76
     77=== Raster3d spacetime datasets ===
     78
     79The raster3d spacetime tables are equal to the raster spacetime tablse, except that the spatial extent is computed based on east, west, south, north, top and bottom.
     80
     81=== Vector spacetime datasets ===
     82
     83
     84== New temporal modules ==
     85
     86New temporal modules must be implemented for registration and un-registration and extraction of raster, voxel and vector maps in süacetime datasets:
     87  * tr.register, tr.unregister, tr.extract
     88  * t3.register, t3.unregister, t3.extract
     89  * tv.register, tv.unregister, tv.extract
     90  * Spacetime modules for resampling, interpolation, time stamp snapping and extraction must be implemented.
     91
     92== Basic Spatio-temporal algorithms ==
     93
     94Extraction is based on where SQL statements or specific time stamps. Interpolated maps are created or existing map ids will be returned.
     95The extraction tool will provide different types of extraction algorithms
     96Nearest neighbour
     97Interpolation (only raster and voxel maps) (linear, quadratic, ...) or
     98first valid time stamp.
     100
     101tr(3).resample -> will create a new spacetime raster (voxel) datasets with a different spatio-temporal resolution, several methods will be available:
     102  * averaging (mean, median, geometric mean, ...)
     103  * summation, multiplication
     104  * max and min functions
     105
     106== Implementation details ==
     107
     108Access to spacetime tables must be implemented as GRASS GIS library:
     109  * Registration and unregistration of maps into spacetime datasets
     110  * Update/creation of base table entries, so the SQL tables can be modified in low level GRASS GIS library functions (creation, deletion of maps)
     111  * Selection of maps from spacetime datasets
