Changes between Version 362 and Version 363 of Grass7/NewFeatures
- 01/05/15 07:12:16 (10 years ago)
TabularUnified Grass7/NewFeatures
v362 v363 322 322 * d.what.rast, d.what.vect, d.zoom: use G7:wxGUI 323 323 * d.histogram: integrated in G7:wxGUI 324 * d.shadedmap: renamed to G7:d.shade (also added G7:r.shade)325 324 * g.ask: use G7:g.findfile 326 325 * g.pnmcat: no longer needed … … 329 328 * g.setproj: use Location Wizard in G7:wxGUI or 'G7:g.proj -c' ('''state plane by county selection needs to be ported''') 330 329 * image processing: 331 * i.class : use G7:g.gui.iclass330 * i.class rewritten as G7:g.gui.iclass (new wxGUI) 332 331 * i.ortho.photo, i.vpoints ('''need to be ported'''; old display architecture decommissioned) 333 332 * i.fusion.brovey: removed, functionality provided by G7:i.pansharpen … … 344 343 * r.median: merged into G7:r.statistics, G7:r.stats.zonal, G7:r.stats.quantile 345 344 * r.out.tiff: use G7:r.out.gdal 346 * r.shaded.relief: renamed to G7:r.relief347 345 * r.stream modules: r.stream.channel, r.stream.distance, r.stream.order, r.stream.segment, r.stream.slope, r.stream.snap, r.stream.stats moved back from relbranch7 to Addons (install with G7:g.extension) 348 346 * r.sum: use G7:r.univar
