Changes between Version 45 and Version 46 of Grass7/NewFeatures74
- Nov 11, 2017, 8:25:31 AM (7 years ago)
v45 v46 146 146 In the past year of development, there were several changes in different GRASS GIS libraries. The most relavant changes are described below: 147 147 * In the rasterlib there is now NULL file compression by default. 148 * The temporal framework has now support for spatial topological operators to the temporal algebra, several tests were added as well as a new function to 149 convert granularity to a smaller granularity, and raster region specific parallel processing has been enabled by means of the MultiModule new class in PyGRASS. 148 * The temporal framework has now support for spatial topological operators to the temporal algebra, several tests were added as well as a new function to convert granularity to a smaller granularity, and raster region specific parallel processing has been enabled by means of the MultiModule new class in PyGRASS. 150 149 * projlib now provides improved integration of GDAL and streamlining of spatial reference system handling, as well as new functions (GPJ_grass_to_wkt2 and GPJ_grass_to_osr2) 151 * libgis has received several major and minor enhancements. There are new functions such as G_adjust_window_ll to automatically fix lat-lon errors and the lat-lon restrictions when reading DMS coords were relaxed. On the other hand, G_window_percentage_overlap now accounts for N == S or E == W. The function 152 G_compare_projections has an enhanced ellipsoid check. Moreover, BZIP2 compression has been improved for speed and support for HTML/CSS hash hexadecimal colors has been added in G_str_to_color. 150 * libgis has received several major and minor enhancements. There are new functions such as G_adjust_window_ll to automatically fix lat-lon errors and the lat-lon restrictions when reading DMS coords were relaxed. On the other hand, G_window_percentage_overlap now accounts for N == S or E == W. The function G_compare_projections has an enhanced ellipsoid check. Moreover, BZIP2 compression has been improved for speed and support for HTML/CSS hash hexadecimal colors has been added in G_str_to_color. 153 151 154 152 == Source Code Portability ==
