Changes between Version 44 and Version 45 of Grass7/NewFeatures74
Nov 11, 2017, 8:23:12 AM (7 years ago)
veroandreo
  • Grass7/NewFeatures74
    v44 v45
    1818=== Releases ===
    1919
    20  * See list here: ~~[wiki:Release/7.4.0-News]~~
     20 * See list here: [wiki:Release/7.4.0-News]
    2121
    2222== Graphical User Interface ==
    144144== GRASS 7 Library changes ==
    145145
    146  * Temporal framework:
    147    * Implemented temporal algebra complement tests that show the current condition bugs
    148    * Added spatial topological operators to the temporal algebra (r71369)
    149    * Tests regarding implicit temporal aggregation
    150    * improved gran_to_gran function to return correctly years and second values
    151    * added function to convert granularity to a smaller granularity
    152    * Enabled raster region specific parallel processing by using the MultiModule class
    153  * projlib:
    154    * improved integration of GDAL and streamlining of spatial reference system handling
    155    * added GPJ_grass_to_wkt2() and GPJ_grass_to_osr2()
    156    * improve creating new spatial reference from embedded proj4 definition
    157  * python vector scripting library:
    158    * added layer variable to vector_info and vector_info_topo functions
    159  * libgis:
    160    * G_window_percentage_overlap() now accounts for N == S or E == W
    161    * new G_adjust_window_ll() to automatically fix lat/lon errors
    162    * relax ll restrictions when reading DMS coords
    163    * support for HTML/CSS hash hexadecimal colors in G_str_to_color()
    164    * G_compare_projections(): compare unit names only if there is no to meter conversion factor
    165    * speed improvement for bzip2 compression
    166    * ignore case when comparing units in G_compare_projections()
    167    * G_compare_projections(): enhance ellipsoid check, combine standard parallels
    168  * rasterlib:
    169    * fix/improve Rast_align_window()
    170  * simlib:
    171    * more control over seeding for random number generator
     146In the past year of development, there were several changes in different GRASS GIS libraries. The most relavant changes are described below:
     147 * In the rasterlib there is now NULL file compression by default.
     148 * The temporal framework has now support for spatial topological operators to the temporal algebra, several tests were added as well as a new function to
     149convert granularity to a smaller granularity, and raster region specific parallel processing has been enabled by means of the MultiModule new class in PyGRASS.
     150 * projlib now provides improved integration of GDAL and streamlining of spatial reference system handling, as well as new functions (GPJ_grass_to_wkt2 and GPJ_grass_to_osr2)
     151 * libgis has received several major and minor enhancements. There are new functions such as G_adjust_window_ll to automatically fix lat-lon errors and the lat-lon restrictions when reading DMS coords were relaxed. On the other hand, G_window_percentage_overlap now accounts for N == S or E == W. The function
     152G_compare_projections has an enhanced ellipsoid check. Moreover, BZIP2 compression has been improved for speed and support for HTML/CSS hash hexadecimal colors has been added in G_str_to_color.
    172153
    173154== Source Code Portability ==
